Seafoam vs. Lucas Engine Complete Treatment
  • 650Dude
  • 650Dude's Avatar Topic Author
05 Mar 2018 10:52 - 05 Mar 2018 10:57
#779782
So you guys know Im not some spammer, but a real dude who has talked to you all about bikes. Ive even made real-life friends here in this forum.
Im shocked.
I was told by everyone under the sun that Seafoam was the next best thing to buying a new engine. Ppl rave about it.
When I walked into Autozone last weekend, I asked for Seafoam and the service person directed me to it, but told me Lucas Engine Complete treatment is better and was on sale. What the heck...iI bought it.
I pulled my 72 CB750 out of the garage (to give my KZ750 and KZ650 a much needed rest), and poured the Lucas Engine Treatment into the TANK, not the crankcase.
All I can say is, MY GOD! This stuff is amazing. My bike PURS and the idle is much more steady.
Im have NO ties to Lucas at all, just passing on some good info. This stuff is amazing!!!
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
Last edit: 05 Mar 2018 10:57 by 650Dude.
  • GPZ1100_Rider
  • GPZ1100_Rider's Avatar
Re: Seafoam vs. Lucas Engine Complete Treatment
05 Mar 2018 13:22
#779787
I'll have to give it a try. I like my chemicals. I used Sea Foam for a while, then came across Chevron's Techron, that seemed to me at least, to work better than Sea Foam.
For winterizing, I also moved away from Stabil after using it for years. I came across Starbrite's Star Tron, and again, from my experiences, works better that Stabil.
If the Lucas brew, doesn't perform up to snuff, I'll run the rest through my car. For ten bucks or so, it's worth a shot.
  • TexasKZ
  • TexasKZ's Avatar
05 Mar 2018 16:07
#779792
:pinch: :woohoo: :blink: :(
I guess it has been a while. This is one of the very few topics that will bring out as much heated discussion as what brand of oil to use.
  • zukdave
  • zukdave's Avatar
05 Mar 2018 17:40
#779796
I just take it apart and clean chit never use snake oils.
Oh and Rotela 15w40 for the win
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • bluej58
  • bluej58's Avatar
05 Mar 2018 17:41 - 05 Mar 2018 17:43
#779797
I like my Marvels ;)
and Rotella 15w40
78 KZ1000 A2A
Last edit: 05 Mar 2018 17:43 by bluej58.
  • Nessism
  • Nessism's Avatar
05 Mar 2018 19:25 - 05 Mar 2018 19:27
#779804
Marine Stabil will keep the varnish at bay. Great stuff. I go a little heavy on the dose and haven't found a downside.
Dumped some Techron into the tank of my kids car since it has been sitting while (he's away at school) and it threw some OBDII codes. Not sure if it helped but the car runs nice now (after I replaced the O2 sensors). Can't hurt but don't expect it to "fix" anything.
Last edit: 05 Mar 2018 19:27 by Nessism.
  • Shdwdrgn
  • Shdwdrgn's Avatar
16 Mar 2018 11:38
#780343
From what I've heard on other forums, Seafoam is bad for fuel-injected engines. I used to run it through the V8 on my old Pontiac and it did wonders, but have been warned NOT to use it on my new SUV. Instead, the Techron has been suggested repeatedly for the fuel-injection and as my truck approaches 150k miles I'm finding it makes more of a noticeable difference.
I still had Seafoam on the shelf though, so I dumped some in the tank on my bike. Considering the crap I had to clean out of the carbs I figured the seafoam would be great to help flush out anything I missed.
Hmm... I wonder what happens if you pour Pine-Sol directly in the tank? :)
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
16 Mar 2018 13:21
#780345
Yep , Its just like the never ending oil debate
And the best tire debate,
And the best gasket debate LMAO
So Why not
I went from the worlds best product Stabil
To Seafoam
To Starbrite Star Tron.
Currently My friendly marine mechanic swears by Star tron and I Do believe it is a good product.
But will tomorrows new best of the best be ???????????
I just finished using my supply of seafoam , so star tron is my next purchase.
Or start using ethanol free gas at 5 bucks a gallon or more.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Mar 2018 15:21 - 16 Mar 2018 15:22
#780349
It seem to have made a difference to me. I added it to each fill up (4), the bike sounds smoother and tighter. After just the first 30 miles the idle came up a little. I thought it was the mix that was doing it but I just filled up the tank again without it and it still seems better. This time I ran it on reserve so I could fill it with fresh gas. I never believed in tune up in a can but the Sea Foam seemed to work on these old 33 Mik's.
Last edit: 16 Mar 2018 15:22 by SWest. Reason: sp
  • cb900f
  • cb900f's Avatar
16 Mar 2018 18:25
#780356
zukdave wrote: I just take it apart and clean chit never use snake oils.
That's my strategy too. I've always marvelled at how I'm the only one that finds these additives haven't done anything in any vehicle I've ever tried them in.
  • Moderator
  • Moderator
16 Mar 2018 18:29
#780357
My usage is in my boat and small motors ( Lawn mower and snowblower. )
Bikes I drain 100 percent when not in use ( Storage )
Short term I just keep fresh fuel in the bike
  • z1kzonly
  • z1kzonly's Avatar
16 Mar 2018 18:43
#780358
Speaking of Marvel (last post) I have been using Marvels Mystery Oil In every engine I have had for 44 years! Lawnmower, snowblower, weed wackers. And my old Shovelhead with the original soft valve seats made for leaded fuel. And the Hemi AA/Gasser! Keeps blower lubed with the methanol fuel. Plus in my 2008 Ford F150 V-8 religiously Truck only has 54,000 miles. Run your finger in across the tail pipe, and your finger stays clean. Got good burn going. No soot or carbon! Is it the LUCAS? I don't know, and don't care. I'll keep using it in the fuel! I get a gallon for $25.99 wholesale price
Plus they (LUCAS) are great sponsors of all types of motor racing. Especially the NHRA drag racing
