How do you put on universal mufflers?
  • kyan44
  • kyan44's Avatar Topic Author
16 Apr 2017 20:53
#759355
Hello guys! So I bought a pair of reverse megaphone mufflers. I am trying to install them and then wrap it up with exhaust wrap. But I have a little problem. The reducers that came with the mufflers are too loose even with the clamp tighen. How does one connect the universal muffler to the exhaust? Does anybody have a solution to this problem?
  • GPzMOD750
  • GPzMOD750's Avatar
Re: How do you put on universal mufflers?
17 Apr 2017 04:56
#759374
Go to your local auto parts supply. They should have a shiny aluminized exhaust repair tape. Wrap it around the end of your pipes to take up the difference between the pipes and the bushings. If you are careful it wont be seen. I've done it on my improvised set up and it works great and is less of a pain than trying to find properly fitting purpose made bushings and gaskets.
  • GPzMOD750
17 Apr 2017 05:08 - 17 Apr 2017 05:09
#759377
Last edit: 17 Apr 2017 05:09 by GPzMOD750.
  • Nerdy
  • Nerdy's Avatar
  • Away
17 Apr 2017 08:07
#759394
kyan44 wrote: Hello guys! So I bought a pair of reverse megaphone mufflers. I am trying to install them and then wrap it up with exhaust wrap. But I have a little problem. The reducers that came with the mufflers are too loose even with the clamp tighen. How does one connect the universal muffler to the exhaust? Does anybody have a solution to this problem?
Normally the person making the purchase would check the OD of the existing pipe and then check the ID of the mufflers to ensure a good fit. :)
The OD should be as close as possible to the ID without being equal to or greater than the ID. This will eliminate the need to fill the gap.
For example, I bought a pair of used headers and a set of new mufflers for my KZ400. The OD of the header is about 1.48" so I bought mufflers with a 1.5" ID. The pieces fit together well and will require only an exhaust clamp. (Do not use a hose clamp for this.)
OD = outer diameter
ID = inner diameter
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • kyan44
17 Apr 2017 15:03
#759438
Ya I know. I should of thought of it more. I should of asked you guys before I bought them........shame on me. But I got to make it work somehow. I will try the exhaust tape
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 Apr 2017 05:44
#759493
Go to an auto parts store and buy the correct exhaust reducer and 2 band clamps.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • kyan44
19 Apr 2017 14:06
#759619
Ok I got the mufflers on, Thank the heavens! But now I am about to wrap the exhaust with exhaust wrap. Which side do you wrap the exhaust? Do you start from the muffler side and wrap up to the engine end? Or vice versa?
19 Apr 2017 14:26 - 19 Apr 2017 14:32
#759621
Be SURE to watch this video all the way to the end; it is quite informative and surprising. Ed
Another example.......
Last edit: 19 Apr 2017 14:32 by 650ed.
  • kyan44
19 Apr 2017 14:40
#759623
Haha wow, you are such a troll....
19 Apr 2017 15:22 - 19 Apr 2017 15:23
#759625
Perhaps. :lol: [hr]
The pipe you show in your pic looks like it is in good shape, so I though you might want to see what pipe wrap will do to the finish. Ed
Last edit: 19 Apr 2017 15:23 by 650ed.
