New camera.
  • zukdave
  • zukdave's Avatar Topic Author
Re: New camera.
18 Jan 2017 20:44
#752464
Messed with the mount's after work using the phone so I could see were it was pointed.
I'm gonna have to remove the helmet mount and turn it I run out of adjustment and can't point
it any higher.
This one is back on the handle bars
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Rockranch
  • Rockranch's Avatar
Re: New camera.
19 Jan 2017 04:46
#752471
Your testing is going well. Quite a difference in the sound of the engine and vibration fuzz. I found some kind of dense rubber-type foam that made a noticeable difference for my HBar mount. It worked much better for mine than the strip of rubber that I first used for a vibration buffer tween the bar and mount clamp, as mine came just bare metal with no buffering.
Mike
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • zukdave
Re: New camera.
25 Jan 2017 15:56
#752902
More testing I changed the res. to 720 @ 60fps and put it on the windshield on
my 01 Connie. and it didn't like looking through the plastic I guess but the purple trees are cool.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: New camera.
25 Jan 2017 16:19
#752903
Will changing the speed take the choppiness out of it? The others were more fluid. Is the windshield tinted? No wind noise this time. ;)
I might have to send my new cam back. Today everything was bleached out. Might be the settings. :unsure:
  • zukdave
Re: New camera.
25 Jan 2017 16:49 - 25 Jan 2017 16:53
#752907
It's the org. factory clear windshield with a lot of Texas summers. It's in real good shape for it's age
but it ain't opticly clear by a long shot but then none really are..
As for the res settings I think to really compare I need to put it back on the bars and the helmet
and ride the same route to the bar in the first video's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 25 Jan 2017 16:53 by zukdave.
  • Rockranch
Re: New camera.
25 Jan 2017 19:58
#752917
Almost like it's getting a rainbow effect through the windshield similar to a prism. Always wondered what effect mine wld have if viewed through a plastic windshield since it's housed inside it's own plastic case. Perhaps the angle combination between the 2 plastics being viewed through a camera lens? Mine has a normal look through a car windshield. hmmm It also has had an occasional waviness that I can't for the life of me figure out. I don't think heat from sunlight. I'm thinking maybe something to do with vibration frequencies combined with a fisheye camera lens. It seemed to help a bit when I changed to a different buffer for my hb mount. ..................................................Mike
1 modified
  • Rockranch
Re: New camera.
03 Feb 2017 13:16
#753575
Were U able to figure out what caused the coloring in your videos?
1 modified
  • apollojm
  • apollojm's Avatar
Re: New camera.
24 Feb 2017 02:23
#755066
Look like a good camera, and the price is tempting.
