- Thank you received: 8
Z1 valve cover metal
- tfh903
13 Oct 2016 15:55 #745180
by tfh903
Z1 valve cover metal was created by tfh903
Cracked the valve cover on my Z1. took it to the local welder, they couldn't decide what kind of metal it is. It does have some magnetism but very little and not the all the same at the 4 ends. Is it Aluminum (has magnetism), Pot metal aluminum, light grade stainless steal, pot metal stainless steel, or other? They need to know to properly weld it.
- Thank you received: 2740
13 Oct 2016 16:02 #745181
by SWest
Replied by SWest on topic Z1 valve cover metal
It's aluminum. Tried eBay? Z1-KZ 900 are the same.
- tfh903
13 Oct 2016 16:20 #745182
by tfh903
Replied by tfh903 on topic Z1 valve cover metal
If aluminum why the magnetism? checking ebay. This one has chrome ends and the rest is powdercoated. I know the powdercoat at the crack will be messed up by the welding but my powdercoater says he can fix that.
13 Oct 2016 16:42 #745185
by SWest
It has chrome on it?
- tfh903
13 Oct 2016 16:49 #745186
by tfh903
yes,, It was all chromed but the chrome was bad except on the 4 ends. So I had my neighbor powdercoat it (except the ends).
13 Oct 2016 16:56 #745187
by SWest
No eBay APP ID and/or Cert ID defined in Kunena configurationThat could explain it being slightly magnetic.
- Kidkawie
- I bleed premix
- Thank you received: 245
13 Oct 2016 18:39 #745189
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Z1 valve cover metal
Yeah, just replace it. Plenty around. Not supposed to be chromed, just aluminum.
1975 Z1 900
2004 KX125
- westmiltonfab
- Thank you received: 23
14 Oct 2016 06:44 #745207
by westmiltonfab
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
Replied by westmiltonfab on topic Z1 valve cover metal
I have welded aluminum for a living my whole life and even though its easy for an experienced welder why take the chance? As cheap as they are compared to an entire engine if the weld fails.IIf your welder cant determine what the parent metal is then they shouldn't be welding it anyway. Just my opinion.
Good luck!
Bill
Good luck!
Bill
14 Oct 2016 07:20 #745209
by SWest
When I busted my cam chain in 78 I used clear silicon and a piece of beer can to cover the hole it left. Lasted until I could get a new one.
Took it out to 1015 at that time.
- westmiltonfab
14 Oct 2016 13:06 #745236
by westmiltonfab
That will work too !!!!! :
- Kawboy74
- Thank you received: 52
14 Oct 2016 16:18 #745249
by Kawboy74
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
Replied by Kawboy74 on topic Z1 valve cover metal
The bare cam covers were usually cast finish throughout with the ends beyond the ribs polished somewhat.
