Please help me ID my bike!
  • lex.entwistle
  • lex.entwistle's Avatar Topic Author
20 May 2016 19:50
#727683
I bought a KZ1000 from a guy on craigslist. all he told me is that it is a 1980 KZ1000. The title says the same. Trying to find out more specifically what kind it is. The rear fender seems to resemble a ltd. Can anyone help? I just want to make sure I am buying the right parts. I need a wiring harness.
-Lex
Re: Please help me ID my bike!
20 May 2016 20:25 - 20 May 2016 20:27
#727688
Can use zedder to help identify the particular model.
> www.zedder.com
> Bike Info
> "Kawasaki Model Information"
Scroll down to "1000 cc arranged by year"
Click on selected model to see info such as range of engine serial numbers, range of chassis (frame) numbers, etc. applicable to the particular model. And compare the range of numbers to the actual numbers on the bike at hand.
Might possibly discover that the engine and frame came from two different models, maybe even different years.
Good Fortune! :)
Last edit: 20 May 2016 20:27 by Patton.
20 May 2016 20:30
#727691
Question -- Is it for certain that a replacement wiring harness is necessary?
Good Fortune! :)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
21 May 2016 04:35
#727717
Another question--do you know where to look on the motorcycle for 1) the motor VIN and 2) the frame VIN? Both of those will allow you to narrow down what you have
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
21 May 2016 05:40
#727724
Take a look on the steering stem neck. You should find a frame number (VIN) stamped into it. You can use that to positively identify the bike's year and model. Take a look at the engine near the oil filler cap. You should find the engine serial number there. You can use that to positively identify the engine's year. It may not be the same as the frame year if a previous owner replaced the original engine. Ed
  • z1kzonly
  • z1kzonly's Avatar
21 May 2016 08:02
#727741
Looks to be a 80 LTD, KZT00AE
Most likely a Mark II engine if the "E" is on engine #
Mix of various parts.
  • lex.entwistle
21 May 2016 17:42
#727797
Thanks! The bike is currently at my friends garage, we are rebuilding it together, so I will ask him for the frame and engine serial number to get a more accurate ID. I know it has a lot of mixed and matched parts. The carbs that came on it were not meant for the engine and the tank was swapped from another bike as well, so it is a bit of a Frankenstein's Monster thing going on.
-Lex
  • lex.entwistle
21 May 2016 17:44
#727798
Unfortunately, The wiring harness currently on the bike has been greatly mangled and modified, so Just trying to get basic things like a tail lamp and head lamp are kind of difficult with the current one :/
Patton wrote: Question -- Is it for certain that a replacement wiring harness is necessary?
Good Fortune! :)
-Lex
  • PLUMMEN
  • PLUMMEN's Avatar
21 May 2016 18:46
#727805
Look for a B in the serial number on steering head .
  • MDZ1rider
  • MDZ1rider's Avatar
24 May 2016 10:12
#728263
Even if you identify the model, I don't think an original wiring harness is going to be of much use. Most of the electrical systems have been stripped from that bike and those that remain are not original. I doubt the builder spent the time to match up the replacement pieces to the original style harness connectors. You've either got to trace and fix the issues in the current harness, or build one from scratch for the circuits you are running.
What state are you in? I hope your state doesn't have any safety inspection requirements.
  • lex.entwistle
29 May 2016 15:50
#729124
I live in Texas. All we need is tail light and headlight and a working horn. I'd like the option to install after market indicator lights in the future and odo/tach with some kind of back light, and LEDs around the bike to be more visible while riding at night. My friend and I are about to take it completely apart, sand it down, install new carbs, fix the wiring issues, and get new tires.
That is the plan, anyway.
-Lex
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
30 May 2016 18:27
#729283
Sounds like a good plan Lex.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
