A clymer service manual my best bet ??
  • Tirefire Pat
  • Tirefire Pat's Avatar Topic Author
  • (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
09 May 2016 16:57
#725418
Hey guys ,I'm not a skilled mechanical person, but I'm trying to do all I can do wrenching on my 1980 1000 b....as a guide a clymer service manual my best bet or do you guys have a different source I can buy help me in any way...thx for any input... Pat
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: A clymer service manual my best bet ??
09 May 2016 17:10
#725422
A factory service manual is the go to source.
For someone starting out with limited abilities a Clymer will do just fine. Or Haynes.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: Tirefire Pat
09 May 2016 17:28
#725425
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo, Clymer and Haynes manuals are definitely NOT your best bet!
Your best bet is a genuine Kawasaki Service Manual (sometimes referred to here as the FSM - factory service manual). Think about it; who would know more about the bike than the folks who engineered and manufactured them?
You usually can find the Kawasaki Service Manual for your bike on eBay. Just be sure you get the one that covers your bike's EXACT year and model. The models the manual includes are usually listed on the back cover of the manual. Assuming that your bike is a 1980 KZ1000 LTD the model is a KZ1000-B4. You will find that the manuals for the KZ1000-B (LTD) models consist of the basic KZ1000 manual for your bike's year plus a KZ1000-B (LTD) supplement that covers the things unique to the LTD. The 1st link below shows a KZ1000-B4 supplement available on eBay. I'm not positive, so someone else should verify, but I believe the manual in the 2nd link is the base manual for the 1980 KZ1000. Ed
  • Tirefire Pat
09 May 2016 17:41
#725426
Ordered the law service manual.. Thx ed
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
09 May 2016 21:44
#725461
Tirefire Pat wrote: Ordered the law service manual.. Thx ed
??? Please explain Pat, I don't understand...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • wrenchmonkey
  • wrenchmonkey's Avatar
09 May 2016 23:35
#725468
I think it was a type-oh for KAW service manual...
Hey Pat, Definitely, you want the FSM for your bike. I got mine as used books but they're perfectly fine. However, if you happen to find a Clymer and it's cheap enough, I'd get it too. I don't trust the Clymer anymore due to inconsistencies they had in their KZ550 manual BUT I have found Clymer sometimes uses different photographs or discusses a particular procedure differently and when combined with the FSM it helped give me a clearer idea of what I was about to do on the bench.
Again, it's just a second reference but I've learned the hard way to trust only the FSM for technical specifications.
  • 80B4
  • 80B4's Avatar
09 May 2016 23:42
#725470
A Clymer manual is a great investment. You never know , they may stop making toilet paper some day
1980B4 1000
1978 Z1R
1978 B3 750
  • Tirefire Pat
10 May 2016 03:28
#725480
I mentioned kaw... Damn auto correct
The following user(s) said Thank You: !Seymore
  • Tirefire Pat
10 May 2016 03:29
#725481
See. ! Ment kaw.....
  • martin_csr
  • martin_csr's Avatar
10 May 2016 04:57 - 10 May 2016 05:03
#725485
In addition to the manual you should also get a couple of good torque wrenches --- one in INCH-lbs & the other in ft-lbs.
Manual stuff. The Kawasaki service manual assumes that the user has some training already, so it may not have much detail in some cases. The clymer or haynes will have helpful hints & how-tos for doing some repairs, such as how to bleed brakes. A couple of problems with the aftermarket manuals is that they sometimes use the same instructions that may not be applicable between models & sometimes the model data is incorrect. A Kaw manual can have errors, but they usually aren't the type that get you into trouble. I think there is one case in which the cam cap torque is wrong in one of the 1000 Kaw manuals, so before following the manual precisely, you might want to spend a couple of minutes to become familiar with the basic torque values for the different sized fasteners. easy.
You have to use some common sense before cranking down a small bolt. The Kaw manuals I've seen have a table that serves as a guide when the specific torque isn't listed. An M6 bolt doesn't require much torque --- in some cases you kinda have to do it by feel if a torque wrench can't be used, such as at some of the exhaust holder nuts.
anecdote. Jamie Oliver had a pasta sauce recipe that called for 13 lemons, so a bunch of people used the specified number of lemons & couldn't understand why the sauce tasted so terrible. It should have said 1 lemon --- 13 was a typo. I'm not much of a cook, but even I know 13 lemons is a lot of lemons.
Last edit: 10 May 2016 05:03 by martin_csr.
  • pete greek1
  • pete greek1's Avatar
11 May 2016 10:43 - 11 May 2016 10:46
#725736
No eBay APP ID and/or Cert ID defined in Kunena configurationI have this manual, it's great because the covers are laminated to protect from grease, dirt or other contaminants
Its also spiral bound, so it stays flat open on the page you're on
but they really nail you on shipping charges, but it was worth it to me, so I also got one for my 76 LTD 900
P.S. when I ordered mine many yrs. ago, shipping charges were about !/2 as much, but still seemed high at the time
Pete
Last edit: 11 May 2016 10:46 by pete greek1.
  • Tirefire Pat
11 May 2016 11:18
#725742
Hey Pete is that eBay post a new one or from long ago???thx Pat
