Polishing tips
  • Tirefire Pat
  • Tirefire Pat's Avatar Topic Author
  • (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
Polishing tips
06 May 2016 19:06
#724977
Hey guys,,I've looked at some of the most polished, sweet imacculate. Bikes I've ever seen on KZ..can any of you give me any tips as to bringing back my parts ,to a mirror shine as I see so often....type of Polish,or methods of making polished aluminum shine...thx for any help..
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Polishing tips
06 May 2016 19:11
#724983
Welcome to KZR
How about posting a couple pictures of the parts you want to polish..
Depending on how bad they are you may want to take extra steps
Dave B) B) B)
  • Tirefire Pat
Re: Polishing tips
06 May 2016 19:41
#724989
Pics of motor
  • Tirefire Pat
Re: Polishing tips
06 May 2016 19:42
#724990
Ok I failed..dammit
Re: Polishing tips
06 May 2016 19:54
#724993
The following user(s) said Thank You: Tirefire Pat
  • wrenchmonkey
  • wrenchmonkey's Avatar
Re: Polishing tips
06 May 2016 21:59
#725010
Hey Pat,
Well, if your bike is whole still and running and you just wanna spruce it up a bit. You can achieve some pretty good results with under $30 of supplies from Home Depot or whatever local home hardware store you have.
Here's an example of what I did with my KZ550a over the course of a day in the garage:
[ Engine Case Shine ]
  • Tirefire Pat
Re: Polishing tips
10 May 2016 17:58
#725608
My first bike was a new ,kz 550/...left over....I think it was 82 or 83....thx very informative... Pat
  • Nessism
  • Nessism's Avatar
Re: Polishing tips
10 May 2016 19:23
#725630
My technique...
-Remove part and wash.
-Use DA palm sander with 220 grit sandpaper to remove corrosion
-Use stainless steel wire wheel in a Dremel to get nooks and crannies and/or some hand sanding
-Use SISAL buffing wheel and BLACK cutting compound to polish part. This stuff will bring the shine up to that similar or above the OEM finish.
-For a mirror polished look you need to then move to a stitched wheel and white/red compound. I don't bother with this but nothing stopping you if you want the chrome look.
