Getting More Top End without ear plugs
  • Kirkpatrick
  • Kirkpatrick's Avatar Topic Author
17 Apr 2016 17:34
#721466
Ok, my 83 KZ550 Sport has pods, jet kit, and Lossa pipe. See below vid. However, as I approach 60 mph in 6th gear, the bike is already at 6000 rpms and setting off car alarms a block away. I was thinking of a 17T or 18T front sprocket with my 530 chain. I am able to rip through the gears pretty quick and am just looking for a longer 6th gear so I can cruise at 80 mph on the freeways.
Thanks,
Brendan
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Getting More Top End without ear plugs
17 Apr 2016 17:57
#721472
On my bike stock is 15T. I have a 16T now. I cruise at 5000 at 80. What you gain in low RPM at speed, you will lose in take off.
  • Kirkpatrick
17 Apr 2016 18:00
#721473
Based on my experience with the bike, it eats the gears. I searched and it looked like the 83 kz550 sport has a 16T sprocket. I could be wrong. Have to pull the cover to verify. Don't mind losing a little "Launch" for a 80 mph cruise speed.
1983 Kawasaki KZ550
1997 Honda CR500
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2016 18:10
#721475
I have a 630 chain so the count is different. With yours the 18T might make a noticeable difference.
  • loudhvx
  • loudhvx's Avatar
17 Apr 2016 22:21 - 17 Apr 2016 22:32
#721512
Gorgeous bike. That is my favorite color scheme for those bikes.
It should be closer to 70mph, or even higher, at 6000. Even with a 15/42, you'd be doing somewhere around 65.
What sprocket do you have on back?
I like 16/38 on the Kz550D/H Gpz's, and that is stock for the gpz's.
My memory could be off, but I thought the Kz550A models came with 16/40. So the Kz550A does turn higher RPMs for a given speed, but the speed difference at 6000 is only a few mph.
My buddy changed his KZ550A to 17/40 and it's basically the same as 16/38.
All chain drive 550's have the same internal crank/secondary gears, clutch gears, and transmission gears, so their internal gearing is the same.
With 16/38, and an 18" rear wheel, with a 120, 90 - 18 tire, 6000 RPM is about 77 mph.
Last edit: 17 Apr 2016 22:32 by loudhvx.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
18 Apr 2016 04:00
#721524
Brendan, what you can do is use a simple spreadsheet to play with front and rear sprocket sizes to see where your final RPM ends up. That way you determine what gear changes will net you the desired RPM level at 65.
I can send you mine if you PM me. It also does the calc for a 630 to 530 chain.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
