KZ650 engine block interchangeable btwn years?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ650 engine block interchangeable btwn years?
24 Nov 2015 18:57
#700408
On the damaged screw I take the bit and use it to reform the slots. Sometimes the sharper one will get enough meat to bight. This is where patience comes in. B)
  • zed1015
  • zed1015's Avatar
24 Nov 2015 23:01
#700418
Yep! just the sprocket cover and inner transmission cover damaged along with the pushrod.
It's only about an hours job to once you have all the parts.
  • TexasKZ
  • TexasKZ's Avatar
25 Nov 2015 04:11
#700439
aenikolopov wrote:
Nessism wrote:
TexasKZ wrote: Be sure the driver has a proper JIS bit, or a modified Phillips. Those are not Phillips head screw, despite how they look.
A #3 phillips bit works fine. Don't scare the man. :S
I've got a philllips impact driver which has on the one hand worked great for phillips screws, but on the other hand stripped out a JIS screw for me. I also have these impact-like screwdrivers.. see www.amazon.com/Vessel-Megadora-Impacta-P...driver/dp/B003BGZ9CO . They idea is that they are solid screwdrivers, but have the impact driver mechanism built into the handle. Anyone tried one yet? They work great as screwdrivers, but that's all I've used them for.
I have not tried one of those, but any time I see a tool with such a long, overly impressive, made up name, I immediately suspect that there is more marketing than tool.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Nov 2015 04:50
#700442
Looks kinda flimsy to me. I've beat the hell out of the drivers and they still work. :whistle:
  • aenikolopov
  • aenikolopov's Avatar Topic Author
25 Nov 2015 20:55 - 25 Nov 2015 21:13
#700582
zed1015 wrote: Yep! just the sprocket cover and inner transmission cover damaged along with the pushrod.
I don't need to crack the case open to replace the pushrod? I had assumed I would for that, even the case wasn't cracked as I had originally suspected.
Last edit: 25 Nov 2015 21:13 by aenikolopov.
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Nov 2015 03:28
#700596
Nope, just pull it out. A few parts and you should be putting HD's to shame again in no time. :lol:
  • Nessism
  • Nessism's Avatar
  • Away
27 Nov 2015 09:29 - 27 Nov 2015 09:30
#700787
Let me know if you can use this seal kit. I stole the crank seals out of it but everything else is still there. You will need the large countershaft seal and several of the medium sized seals during replacement of the transmission cover and sprocket cover.
[IMG
Last edit: 27 Nov 2015 09:30 by Nessism.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Nov 2015 10:55
#700800
That's great. It has the three seals for the snifter and everything.
  • aenikolopov
28 Nov 2015 11:21 - 28 Nov 2015 12:24
#700959
Thanks all for the help. I was able to get over to the bike and take a closer look at the damage. As several of you had predicted, it's really just the pushrod, chain guide, and gasket and transmission covers that were damaged, so I'm breathing a heavy sigh of relief. I've found all the parts on ebay, looks like it's going to cost me just about $80.
A somewhat gentle pull of the clutch pushrod didn't take it out, but it is bent and may need some more force behind it.
Nessism, thanks, I could very much use that oil seal kit. I'll PM you.
Last edit: 28 Nov 2015 12:24 by aenikolopov.
  • zukdave
  • zukdave's Avatar
28 Nov 2015 11:53 - 28 Nov 2015 11:55
#700964
One thing the has not been said is when you pull the pushrod out theres a ball that will roll
out and hide REAL good while your backs turned and you'll be all pissed when you put it all back together
and the clutch don't work.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 28 Nov 2015 11:55 by zukdave.
  • aenikolopov
28 Nov 2015 12:01
#700966
zukdave wrote: One thing the has not been said is when you pull the pushrod out theres a ball that will roll
Hah! I'll make sure to be ready for it. Thanks.
  • aenikolopov
30 Nov 2015 08:05
#701212
Just leaving this here for others' reference in the future. They have made good screwdrivers, like I said, but I just dealt with 3 stuck screws, and this Megadora driver's 'impact feature' didn't do anything for them. A standard heavy handheld impact driver loosened each screw up easily.
