Shaft drive
  • gpz1170
  • gpz1170's Avatar Topic Author
Shaft drive
09 Nov 2015 08:36
#697927
I'm thinking of a winter project and was wondering how much abuse a KZ drive shaft can take? Has anyone built one ? The reason is I have most everything need, the bike (1983 ZN1100 B), the parts (block/pistons, cams, carbs and pipe ) sitting on the shelf.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • zukdave
  • zukdave's Avatar
Re: Shaft drive
09 Nov 2015 15:48
#697990
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • gpz1170
Re: Shaft drive
10 Nov 2015 07:59
#698056
won't let me view ???
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • zukdave
  • zukdave's Avatar
Re: Shaft drive
10 Nov 2015 15:54
#698133
Its a ZL1000 with a ZRX1100 motor and ZG1000 six speed tranny.
I'll ask him to post it here he's a member.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • gpz1170
Re: Shaft drive
11 Nov 2015 15:24
#698276
what I'm really concerned with is the drive shaft itself, how much horsepower is too much. Building the motor is not an issue, it's how strong is the drive shaft compared to a chain ?
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Shaft drive
12 Nov 2015 04:34
#698329
how sticky the tire is will have a big effect on how much torque gets to the shaft.
i have seen some nicely built 1075cc shaft drive bikes and never heard of a shaft breaking.
but the v-max drag bikes get converted to chain drive most of the time.
hth,
  • gpz1170
Re: Shaft drive
12 Nov 2015 14:58
#698382
I guess what I'm trying to do is build something of a " sleeper ". I have ( 1983 GPZ 1100 ) and have built a couple KZ's with this same combination that have run in the low 10/ high 9 sec. range. Also know that without more tire, longer arm and probably a gear change that won't happen. But it might be a fun ride.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • 531blackbanshee
  • Vendor
  • Vendor
Re: Shaft drive
13 Nov 2015 03:39
#698427
build it.
fix whatever breaks better than it was before :evil: !!!
custom chrome-moly driveshaft???
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Shaft drive
13 Nov 2015 04:18
#698436
My neighbor was a co owner of a dealership in CO. He was riding the new KZ 1000 shaft to UT and his partner was a KZ 1000. Without warning the rear tire locked up at speed. He had just taken a drink from his cooler cup when it happened. He managed to keep it upright but had Coke all over him. A pick up took him into town and he was able to fish out the broken teeth with a magnet, put heavy gear oil in it and get to his destination. There were no recalls that he knew of but when I read about HP builds with these bikes, I think about that. :unsure:
  • gpz1170
Re: Shaft drive
13 Nov 2015 09:29
#698494
Thanks Leon and Steve
I think my biggest issue will be tire/swing arm size. I'm pretty much held to stock ( 130/70 ) I believe. My GPZ has a 190/55x17 with 6" over, it works well. I agree with you, Leon, build it and ....... . Steve, I've thought about breakage too. Wonder why the gears would break ? I would think other things would break first, But it should be different.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Shaft drive
13 Nov 2015 09:40
#698495
I was a demo model. First out. Maybe it was a fluke or they got it sorted out. Automatic cam chain adjusters were recalled about the same time.
