$350 to swap fork springs on a zr550??
Re: $350 to swap fork springs on a zr550??
03 Oct 2015 11:10 - 03 Oct 2015 11:12
#693154
I seriously doubt it. The picture shows a bike whose weight is 99% on the centerstand. The jack in the picture is only applying enough pressure to the front of the engine area (pipes) to shift the weight toward the rear of the bike. This is pretty much the same thing I did with my bike on the centerstand when I worked on my forks, only I used a bottle jack under the front of the engine. Ed
Attachment ForkOff2-2.jpg not found
Last edit: 03 Oct 2015 11:12 by 650ed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Oct 2015 11:19
#693157
That's how I do it. I'd never toss my center stand. You could lay the bike on it's side with the tank removed. Sheesh. :S
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
04 Oct 2015 04:34
#693243
OK, think I have a plan. I'm going to lift the front end with my Viper fork stand, slide some 2x4's under the frame, and rest the bike back down on the 2x4's. Should be easy peasy. I'll let you know how it works. There's remarkably little info on the Intertubes about how to lift a bike with no center stand.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • pete greek1
  • pete greek1's Avatar
04 Oct 2015 08:34
#693275
I found this on another Kawasaki site
If you have open rafters in your garage get a couple of pieces of 2x4 or 2x6 & put a couple of eye bolts the threaded ones, NOT lag bolts, so you can put a nut on the other end of the eye bolts, & use a couple of ratcheting hold down straps to lift it, couldn't get pics. to post here, so just look at the last post on this thread
www.google.com/url?sa=t&rct=j&q=&esrc=s&...DGU9mVzJcYd908Xzrf1w
Pete
  • zukdave
  • zukdave's Avatar
04 Oct 2015 09:59
#693283
I knew Ed pampered his bike but damn it's got it's own pillow and blanky
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
04 Oct 2015 10:03
#693285
:laugh: :laugh: :laugh: :laugh: Well, I do read it a story and tuck it in every night. I thought that was normal, but now I'm having second thoughts. :blush: Ed
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
05 Oct 2015 02:15
#693380
After fabbing all these comtraptions, its probably quicker just pulling the header.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Tyrell Corp
  • Tyrell Corp's Avatar
05 Oct 2015 02:35
#693381
Bear in mind you might need more than just springs and $350 : top and / or bottom bushings plus oil and a pair of seals and new copper crush washers at the bottom.
You could do this yourself, pvc pipe for an oil seal driver and a helper to compress the fork to remove the bottom bolt.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
05 Oct 2015 03:44
#693395
If ONLY labor was $350, that's a "we don't want to do it" quote.
Any reasonable shop would charge $350 including springs, seals, bushings, fluid and labor.
1975 Z1 900
2004 KX125
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
05 Oct 2015 05:34 - 05 Oct 2015 05:35
#693413
I find the dealer shops around here aren't interested on working on older bikes and usually farm them out to other smaller shops.
Labor rates around here are $100+ an hour so depending on what is included, it can get expensive quick!
Build Thread
Last edit: 05 Oct 2015 05:35 by tachrev.
