$350 to swap fork springs on a zr550??
- Zaddict
- Enjoying my Zaddiction!
02 Oct 2015 15:19
That's what I just got quoted. That's just for labor - I'm providing the springs. Seems insane to me. Granted, I'm in SF where prices in general are insane, but isn't that a 1hr-ish job?
I'll probably just do it myself. Just need to figure out best way to jack up my bike.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Re: $350 to swap fork springs on a zr550??
02 Oct 2015 17:15
Shop prices.
- StreetfighterKz
Re: Re:$350 to swap fork springs on a zr550??
02 Oct 2015 17:29
If you have a center stand, you can place a board and jack under the header and carefully raise the front end up.
I've also taken a jack under the right footpeg and jacked up the bike while propping it up on the side stand.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- Kidkawie
- I bleed premix
03 Oct 2015 00:48
If youre only doing springs, all you have to do is loosen the top clamp pinch bolts, remove the cap and pull out the spring.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- StreetfighterKz
03 Oct 2015 02:57Kidkawie wrote: If youre only doing springs, all you have to do is loosen the top clamp pinch bolts, remove the cap and pull out the spring.
...with no weight on the front end.
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
03 Oct 2015 03:29 - 03 Oct 2015 05:14
As is usually the case with an old bike, I bet the forks need to be completely serviced to clean out all of the old grey gook. For someone who's never done it before, the first fork can be a bear to do. After learning how to do it, the second one should be easy,
PS: I made a simple engine block stand --- 2x4s sandwiched together w a 2x8 base. bike on center stand & engine supported by homemade stand.
Last edit: 03 Oct 2015 05:14 by martin_csr.
- JR
03 Oct 2015 03:34
I used to prop a 2x4 under the triple tree but it was a tad ubstable and so I got a little bit more creative
www.kzrider.com/forum/21-tools/595750-ra...wheel-off-the-ground
You just need to raise the front enough to get the wheel off
03 Oct 2015 05:51
Wow. I'm really glad my bike came with a centerstand. I can pull the front forks, rear wheel, swing arm, etc. using it. The only help it needs is a small bottle jack under the front of the engine when pulling the front wheel or forks. It's a shame that newer models didn't at least have a boss or bracket underneath to allow a centerstand to be mounted temporarily for repairs and maintenance. I wonder if such a thing could be welded under the frame for that purpose? It sure would make life easier for folks with bikes that have no permanent centerstand. Ed
03 Oct 2015 06:41
How do they fix flats on the road? Poor planning if you ask me. :dry:
03 Oct 2015 07:17
I guess they must call for a tow truck to haul the bike to a motorcycle shop. That would be very convenient on a Sunday evening when all the bike shops are closed and you're 100 miles from home. :whistle: Ed
- Zaddict
03 Oct 2015 07:26 - 03 Oct 2015 07:51
Yeah, no center stand is a real bummer. So is no kickstart as a backup when the battery runs out of juice.
Anyway, found this clever little solution to lifting the bike on Zephyr Zone. Think I'll give it a shot, though I might go with a floor jack instead.
Attachment bikepics-2198734-800.jpg not found
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Last edit: 03 Oct 2015 07:51 by Zaddict.
The following user(s) said Thank You: Tyrell Corp
- Zaddict
03 Oct 2015 07:52 - 03 Oct 2015 07:53
Hmm, just noticed the bike in the pic I posted has a center stand. Wonder if this would be a stable enough solution without it...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Last edit: 03 Oct 2015 07:53 by Zaddict.
