Exhaust Gaskets for '83 KZ1100 LTD
- kz_fl
01 Oct 2015 14:48 - 03 Oct 2015 17:30
Hey guys. I'm in the middle of a restore project on an '83 KZ1100 LTD. I took the pipes off to wrap them to keep from burning the shit out of my legs, and upon attempting reinstallation, realized there were no gaskets installed where the pipes fit against the exhaust manifold. I'm looking on eBay to find some cheap gaskets and cannot seem to find any specifically for the LTD model. They only have them for the A, D, J and M models. Can anyone explain the difference between mine and these other models, and can you tell me if any of the gaskets for these other bikes will fit on mine? Thanks for your help.
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
Last edit: 03 Oct 2015 17:30 by KZQ. Reason: Make topic searchable
Re: What's the difference?
01 Oct 2015 14:50
They should fit your bike. Why are you wrapping the pipes again? Pics?
- kz_fl
01 Oct 2015 15:07
The pipes were scraped from when a past owner dropped it. You can see the damage in the picture where I haven't wrapped yet. I'm taking some liberties in restoring it and customizing it to my style.
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
02 Oct 2015 03:48 - 03 Oct 2015 03:09
That's an aftermarket exhaust system. You might want to get different exhaust port gaskets from stock, as the copper crush gaskets may not seal properly. Z1Enterprises.com carries fiber gaskets that are thicker than stock & I think they are reusable 1 or 2 times.
Last edit: 03 Oct 2015 03:09 by martin_csr.
The following user(s) said Thank You: kz_fl
- Mcdroid
- Gone Kwackers
02 Oct 2015 05:08
To answer your question:
Your model = KZ1100-L1 LTD
A model = KZ1100-A1/A2/A3 Shaft
D model = KZ1100-D1/D2 Spectre
J model = KZ1000J1/J2/J3 Standard
M model = KZ1000M1/M2 CSR
Many of those gasket sets are interchangeable between all those models.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- pete greek1
02 Oct 2015 08:49Its hard to tell from the picture, but It looks like you started wrapping from the top downkz_fl wrote: The pipes were scraped from when a past owner dropped it. You can see the damage in the picture where I haven't wrapped yet. I'm taking some liberties in restoring it and customizing it to my style.
If you did, you did it wrong & you're creating more problems for your pipe
Pete
- Kidkawie
- I bleed premix
02 Oct 2015 09:27pete greek1 wrote:Its hard to tell from the picture, but It looks like you started wrapping from the top downkz_fl wrote: The pipes were scraped from when a past owner dropped it. You can see the damage in the picture where I haven't wrapped yet. I'm taking some liberties in restoring it and customizing it to my style.
Pete
Was going to mention it looks like they're wrapped backwards.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- kz_fl
02 Oct 2015 12:31
They're wrapped bottom to top. This is my first time ever wrapping pipes so I'm glad I happened to do it correctly. Didn't think it would make a difference. What issues would it cause if wrapped the other way?
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
- missionkz
02 Oct 2015 12:35
Same as shingles on your roof!! Bottom up so water runs over the lap joints and onto the next lower
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- kz_fl
02 Oct 2015 12:54
Well damn. That makes sense!
1980 kz650
1983 kz1100 LTD
1983 kz1100 LTD
- pete greek1
02 Oct 2015 13:10+ 1,missionkz wrote: Same as shingles on your roof!! Bottom up so water runs over the lap joints and onto the next lower
Pete
- The Gringo
- ¡Usted no necesita otra motocicleta!
03 Oct 2015 17:00
Before you put the header pipes back on make sure you have removed the old gaskets from the head. Take a small screwdriver or preferably a pick and make sure that the old crushed copper gaskets have been removed. They tend to get stuck up in there. Sometimes you will find two complete sets in the head if the PO didn't know to pick the old ones out he may have installed new gaskets on top of the old ones. I've seen this before. Also when installing the new gaskets smear some type of grease on them to help keep them in place while installing the pipes. I usually just use some Vaseline which will easily burn off and melt away once you start the engine.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
