I found a bike on CL
  • Silverslugger00
  • Silverslugger00's Avatar Topic Author
13 Sep 2015 22:14 - 13 Sep 2015 22:25
#689958
So I found a 1982 KZ1000 ON Craigslist for $1000. My knowledge is limited on older bikes and I went and looked on Nada for a pricing suggestions. I'm wonder how much is this bike worth really, and how much would it cost me in parts to get a carb? I don't mind learning and taking my time. But I would love advice on this bike. Thanks in advance.
1982 kz 1000 $1000 cash - $1000
houston.craigslist.org/mcy/5218382977.html
Last edit: 13 Sep 2015 22:25 by Silverslugger00.
  • LineArtist
  • LineArtist's Avatar
Re: I found a bike on CL
14 Sep 2015 01:54
#689964
I would say a running 1000 from that year, in that condition would be worth about $800-1600. Otherwise it's a non-running bike with missing parts. Try to make a sale around $500 or less if you are really interested. Make sure there are papers for registration if you plan on spending money.
You are buying a bike without knowing if and how the engine is running, and all other parts. If this is your first or dream bike and you have extra cash and mechanical skills, go for it.
If you want to ride sooner rather than later, then find a good running bike for the same price (plenty out there). I got my 1979 KZ650 for $0.
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
  • martin_csr
  • martin_csr's Avatar
14 Sep 2015 03:06 - 15 Sep 2015 02:37
#689968
The bike is a KZ1000-M2 CSR. I would offer $500. The asking price might not be terribly high, though. It's going to take another $500-1000 or so.. If you get it into good running condition, it might be worth $3500 or thereabouts. I would assume $2500 max re-sale.
Don't believe anything the owner says --- people forget, don't know or flat out lie. sad but true
Last edit: 15 Sep 2015 02:37 by martin_csr.
The following user(s) said Thank You: Silverslugger00
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Sep 2015 03:46
#689975
Missing one carb? Double pics, upside down pic of the speedo? Watch it.
  • punisher11b
  • punisher11b's Avatar
14 Sep 2015 05:04
#689987
I have never paid more than $500 for some real nice KZ's (running in most cases). Ones that needed work bit still in great shape. If your planning on working on it that's what I would offer for it. Maybe a bit more depending on specifics of that bike. $1000 seems pretty steep from the pics.
Just My 2c
- good luck
  • Silverslugger00
Re: Re:I found a bike on CL
14 Sep 2015 05:46
#689993
Thanks everyone I will keep this all in mind. Will talk to the seller and see if we can get it for 500 or I will just walk away.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Sep 2015 05:48
#689994
For $1000, you should be able to ride away. :whistle:
  • Tyler
  • Tyler's Avatar
14 Sep 2015 06:05
#689997
swest wrote: For $1000, you should be able to ride away. :whistle:
For a bike like that I agree.
Its been sitting in the elements for a long time, engine could be stuck, have been stuck and freed up.
Yeah I'd start at $300 or $400 and negotiate from there... that's just my take on it from the pictures.
"74 Yamaha DT 400 Enduro
  • zukdave
  • zukdave's Avatar
14 Sep 2015 07:43
#690014
I just called and talked to the guy sounded straight up said the
story on the missing carb is they needed cleaned so his brother took them to clean
them and went to jail. Said he went to get them and the one carb was missing.
Said it was a driver last march has rust free tank, new tires, no tears in the seat
and been stored inside.
Needs the one carb, one mirror and the front brake lever.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Xl ED
  • Xl ED's Avatar
14 Sep 2015 12:08
#690045
Tell him to put them on and get it running and you will give him a thousand.
I don't live to ride, I ride to live.
  • Jussumguy
  • Jussumguy's Avatar
14 Sep 2015 14:17
#690075
Around central California if you see one on Craigslist and don't drop everything and go get it it will be gone. Scarcely time to discuss it with anybody.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Sep 2015 14:18
#690076
A set of 26's will run $200 used. Id start at $600 and go from there. If they have been apart they're just that, parts.
