info on building a performance exhaust?
- DoctoRot
Re: info on building a performance exhaust?
27 Jul 2015 15:59 - 27 Jul 2015 15:5980B4 wrote: I will wate untill someone has custom pistons fabricated and then I buy in on a minimum order. I am also looking at pistons from other motorcycles. The hold up is the pin diameter, it's big. I am also looking into having the rods modded to accept smaller more common pins. I've been lucky at finding 750b engines on Craigslist, I have 4 so I can build one and keep one mostly stock If I find an easy way to go big I'll let you know.
YES. if you find any piston buy-ins count me in on a set. Looking forward to the motor you're going to build.
Tyrell Corp wrote: I'd recommend looking at '4 stroke performance tuning' by A Graham Bell
Thanks Tyrell, I just picked that book up used off amazon.
I personally find this all very interesting. and i agree, on my stock motor the exhaust design probably won't have much of an impact, but i would like to design it so that if future engine mods are done the pipe will still be effective, or at least easily modified. looking forward to reading that book.
Last edit: 27 Jul 2015 15:59 by DoctoRot.
