Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
28 Mar 2020 18:57
#822071
The rings aren't seating. I need to take a long trip then maybe they will.
  • SWest
  • 10 22 2014
29 Mar 2020 15:04
#822140
The plugs are looking better and the insert isn't leaking.
  • SWest
  • 10 22 2014
30 Mar 2020 21:16
#822246
They were leaking.
  • SWest
  • 10 22 2014
31 Mar 2020 19:19
#822343
They work.
  • SWest
  • 10 22 2014
01 Apr 2020 13:50
#822408
More progress
  • SWest
  • 10 22 2014
02 Apr 2020 11:54
#822481
I think the jetting is good just these 33's are a PTIA to dial in. :unsure:
  • SWest
  • 10 22 2014
02 Apr 2020 18:23
#822501
I got it really close. Only a slight miss at 4000 from one carb. I'll get it. Not done with the plug insert yet. :dry:
  • SWest
  • 10 22 2014
05 Apr 2020 20:11
#822681
Got this done now for the insert.
  • SWest
  • 10 22 2014
06 Apr 2020 20:02
#822769
Took two tries but I got it. B)
This is a condensed version
  • SWest
  • 10 22 2014
07 Apr 2020 09:23
#822798
Looks like it's good to go. :woohoo:
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
07 Apr 2020 09:31 - 07 Apr 2020 18:42
#822799
Diligence is worth it in the long run.
The Dynatek solid core plug wires with NGK Resistor caps have 5+ ohms resistance, and the Taylor Resistor Core wires with Non-Res Accel caps have 3.8
Go figure
:S
P.S. With NGK BR8EVX Resistor spark plugs, I thought there would be an excessive resistance problem with the Taylor Resistor Core wires.
But, that doesn't seem to be. I don't get that, because I seemed to have an issue using the NGK Resistor Caps and those same Resistor plugs some time ago.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 07 Apr 2020 18:42 by daveo.
  • SWest
  • 10 22 2014
07 Apr 2020 10:42
#822805
The caps I have are non resister. I'd like to get some blue Taylor wires though. :whistle:
