Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
09 Jan 2020 15:19
I hate to tear down a good running motorcycle but it has to be done.
(Continued from my Cam Tower Caps thread)
kzrider.com/forum/2-engine/611611-kz1000-cam-tower-caps
10 Jan 2020 06:52
I was right about fitting the caps to the Andrews cams.
10 Jan 2020 19:19
Getting the head off was a PITA.
11 Jan 2020 07:29 - 11 Jan 2020 07:30
Looks like this will be a good head.
Last edit: 11 Jan 2020 07:30 by SWest. Reason: sp
11 Jan 2020 13:54
Took everything off I need.
- daveo
11 Jan 2020 18:52
Bossie is in good hands.
1982 KZ1100-A2/1170 sleeper 😀
11 Jan 2020 20:29
Now to bench set the lash.
12 Jan 2020 20:39
This is going to take a while.
13 Jan 2020 12:27
Doesn't look good but I'll use the best I have.
13 Jan 2020 18:31
Rookie mistake. :blush:
13 Jan 2020 19:09
Help out a rookie... How did you bend a valve installing the cam???
13 Jan 2020 22:04
When setting the valve lash on the bench you can only use one cam at a time or risk one valve coming in contact with another. I forgot that. . :blush:
