Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
08 Feb 2018 19:30 - 08 Feb 2018 19:31
#778408
They're working good. I guess they reset after a while. How long I'll find out.
Last edit: 08 Feb 2018 19:31 by SWest.
  • SWest
  • 10 22 2014
09 Feb 2018 19:27
#778448
The forks looked naked without it. :dry:
  • SWest
  • 10 22 2014
11 Feb 2018 07:56
#778527
New bolts.
  • SWest
  • 10 22 2014
12 Feb 2018 07:18
#778585
I'm liking them. B)
  • SWest
  • 10 22 2014
17 Feb 2018 18:59
#778932
Not going to be just valve lapping this time. :dry:
  • SWest
  • 10 22 2014
18 Feb 2018 18:11
#778972
Might be able to get the valves out.
  • missionkz
  • missionkz's Avatar
22 Feb 2018 01:27
#779158
Do you have a multi angle seat cutter set?
If the seats are not beat up, keeping the margins in mind, you might be able to lap in the other valves with very little trouble.
If they are a little wide, maybe using spring shims will increase pressure seal enough anyhow.
I say that because it’s not a race engine and your not constantly flogging it.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • 10 22 2014
22 Feb 2018 07:32
#779178
My friend Jeff has a set. I may wind up replacing the guides as well.
"I say that because it’s not a race engine and your not constantly flogging it."
:lol: You've seen my clips, when don't I flog it? :woohoo:
I just wish I could afford to send it to Larry or someone like him to perform their magic.
I'd like to get back into it to install crank studs and have the crank welded but that's not in the cards.
A 1105 kit would be nice too.:whistle:
  • SWest
  • 10 22 2014
22 Feb 2018 20:53
#779208
Finally got to the harness. Pardon my potty mouth. :blush:
  • SWest
  • 10 22 2014
23 Feb 2018 19:43
#779251
Almost there.
  • SWest
  • 10 22 2014
25 Feb 2018 21:39
#779373
Still more bugs to work out.
  • SWest
  • 10 22 2014
26 Feb 2018 21:02
#779450
Found it. B)
