Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
19 Mar 2017 08:19
I'm going back in to make that one race fit easier. While spinning the crank I can feel a slight bind. Jeff said if this was a babbitt bearing crank it would be more critical. I noticed some chattering at low idle and the crank was walking around. You can see the wear marks at the end of the one clip. I have the potential of doubling the HP so this is a MUST DO.:whistle:
19 Mar 2017 16:27
Good to go, starting on paint.
19 Mar 2017 21:35
Shouldn't be long now.
20 Mar 2017 13:06
So much for the bracing. Another hole to fall into. Putting the lower end anyway.
- missionkz
20 Mar 2017 15:07 - 20 Mar 2017 15:08
Back many years ago, when I lived in Detroit, I worked in a small moto speed shop that also did frame mods to Z1s and H2s.... they would ALWAYS, strip the frame clean, weld up the Z braces and what not, then send the frame out to be heat relieved/annealed, then repainted or powder coated.
Their claim was that welding the frame cold and just reassembling could add all kinds of stress points to the frame... causing possible failures later when out rockin' the dog.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 20 Mar 2017 15:08 by missionkz.
The following user(s) said Thank You: mopguy
20 Mar 2017 21:21
I've read different stories about it.
20 Mar 2017 22:02
Tranny still looks good.
21 Mar 2017 11:43
Got the bottom end in.
21 Mar 2017 11:52
a lil closer!
21 Mar 2017 12:18
May have the head on this afternoon. Gotta bring in that nasty exhaust system and clean it tonight. May be running by noon tomorrow.
21 Mar 2017 19:54 - 21 Mar 2017 19:54
I hope to have it running tomorrow. Looks like rain. :S
Last edit: 21 Mar 2017 19:54 by SWest.
- missionkz
21 Mar 2017 20:50 - 21 Mar 2017 20:55
My manual calls for a limit of 19.5ft lbs for the main center cap. I think same for the 8mm ones.
never mind, ...I just re-watched and heard you say about 18ft lbs.....
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 21 Mar 2017 20:55 by missionkz.
