Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
06 Dec 2016 05:18
#749631
No, 58 as opposed to 66.
  • KZB2 650
  • KZB2 650's Avatar
06 Dec 2016 06:49
#749641
Wow I thought I read one time it was only a 3mm difference...... 8mm that's like 5/16ths of an inch isn't it?.... Have no idea but man you might a been running 6 or 7 to 1 with that don't you think ??
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • 10 22 2014
06 Dec 2016 07:07
#749644
Yeah, with the Wiseco's I didn't notice it. When I lunched another piston and had to use the stock 1000 pistons that came with the 1015 barrels, it was obvious. It still ran great, a little better when I put the 10.25/1's back in. I still haven't done a compression test. I will before I tear it down again. Says a lot about these motors. B)
  • missionkz
  • missionkz's Avatar
06 Dec 2016 16:19
#749679
swest wrote: No, 58 as opposed to 66.
Wow.... I never realized that you were down 165cc at 6:1 - 7:1 compression ... You're going to have to learn how to ride all over again!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • 10 22 2014
06 Dec 2016 17:12
#749680
Might be a blessing in disguise. How did you come up with those figures?
  • missionkz
06 Dec 2016 18:16
#749687
swest wrote: Might be a blessing in disguise. How did you come up with those figures?
wild ass guess and shorter stroke with same bore as a 1015 engine?
Bruce
1977 KZ1000A1
  • SWest
  • 10 22 2014
06 Dec 2016 18:20
#749688
I'm going to fix my compression tester. It'll give us a better idea what it is. :whistle:
  • missionkz
06 Dec 2016 18:26
#749690
I wish I would have written it down but I think mine was around 175psi a couple weeks after I put the 1075 kit in.
That was about 5000 miles ago.
Bruce
1977 KZ1000A1
  • missionkz
06 Dec 2016 18:54 - 06 Dec 2016 19:04
#749692
OK daydreaming.
58mm stroke with 70mm bore?
So 35sqrd x3.1416 x 58
892cc?
But you are running those 70mm 10:1 pistons so ... even with the stroke not pushing the piston further up into the combustion chamber, your actual compression is probably more then 8:1.
Bruce
1977 KZ1000A1
Last edit: 06 Dec 2016 19:04 by missionkz.
  • SWest
  • 10 22 2014
06 Dec 2016 19:01
#749694
I want to weigh both cranks to see if there is a difference or if it's just shorter rods. Looks like something that hasn't been done before. :)
  • cjcrug
  • cjcrug's Avatar
10 Dec 2016 02:23
#749876
Nice pass man, looks like it pulls purty good
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Andrews cams
81 kz 1000 csr
Wiseco 1075
  • cjcrug
  • cjcrug's Avatar
10 Dec 2016 02:26
#749877
Lol idk how my post got two pages forward, it was a reply to the video
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Andrews cams
81 kz 1000 csr
Wiseco 1075
