Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
18 Sep 2015 15:31
I had these on the bike when I parked it for 15 years. Cleaned out the tank and ran them until I got new ones. Only issue is they can break if abused.
- missionkz
18 Sep 2015 18:20 - 18 Sep 2015 18:21
Steve and a few of his buddies trying to decide if this is the crank he's been looking for to eliminate any question about the 750 crank possibly
installed previously...
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 18 Sep 2015 18:21 by missionkz.
- Tyler
18 Sep 2015 18:26
Must stuck working in the heat... I couldn't stand it myself.
Lookin good man. You are still at stock bore? 1015 Weisco's?
"74 Yamaha DT 400 Enduro
18 Sep 2015 18:57
The heat just started today. Swamp cooler is acting up, had a box fan this morning while doing my jets. I have lots of low end. Coming home I was behind a plumbing truck. He wouldn't let me by. Instead of dropping down, I just rolled on the throttle and passed him. Can't wait for 500 miles to come. Using the power up and down, changing speeds etc. Has a deeper growl to her.
Yeah, 1015 and 10.25/1 pistons but with the 2.5mm drop, I'll bet it's more like 9-9.5/1. Good enough for me. :whistle:
18 Sep 2015 18:59:woohoo: Now that's a crank. :lol:
- Tyrell Corp
19 Sep 2015 04:47 - 19 Sep 2015 04:49
What's the deck height on that :laugh: Some of these marine deisel engines are the size of a block of flats, quite amazing really.
I think about 1 point drop in CR for every 1mm, so down about 2.5 points? 10.25 - 2.50 = 7.75
Is it 8.5: 1 standard? If your head has been skimmed at all that will get some back. If the exhaust valve timing lines are just a bit higher than the gasket face it is one indication that the head has been skimmed.
About 3% power for every point of CR, so I guess you are down less than 10 percent. They do run nice and smooth though you have noticed.
www.daytona-sensors.com/tech_tuning.html
Attachment Compression_Power.gif not found
Last edit: 19 Sep 2015 04:49 by Tyrell Corp.
19 Sep 2015 04:54
I'm going to do a compression test just to see.
- KZB2 650
19 Sep 2015 04:55 - 19 Sep 2015 04:55
A comp test at 500 and at thousand miles will tell you the real numbers. Mines at 165 last check so thinking its right at 10/1 or a hair under.
Whoops too slow. :laugh:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 19 Sep 2015 04:55 by KZB2 650.
19 Sep 2015 04:59Tyrell Corp wrote: What's the deck height on that :laugh: Some of these marine deisel engines are the size of a block of flats, quite amazing really.
Looking at your chart makes me want to get a 903 crank. On the other hand, I shouldn't have any problems running regular gas. :whistle:
19 Sep 2015 06:03
I guess it's time to close this one out. If anyone has some info on the Z2 750 crank, rod markings, numbers on the crank throws etc. Please post them here. I am confident it is a 750 crank but little is available on identifying markings. I started the Poser thread in response to one members questioning my truthfulness. Rather than stoop down to his level, I did my best to prove what I claimed is true.
In the end, I satisfied the question if nothing more than to myself.
- z1kzonly
19 Sep 2015 06:06I went out to the Bar at Lunch and burned a fatty :woohoo:
19 Sep 2015 06:10
That stuff makes me stupid. I don't do it anymore. :lol:
