Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
20 Jan 2022 13:10
- daveo
20 Jan 2022 16:14 - 21 Jan 2022 06:09
Hey Steve, I'm still using the cut strips of 1/16" thick HDPE sheet material behind the hose clamps to hold the rings in. The slick material surface protects the pistons as the sleeves slide past. Besides that, the sleeves engage with the entire 1/16" strip edge, and glide over the rings when the clamps are snugged just right.
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
Last edit: 21 Jan 2022 06:09 by daveo.
21 Jan 2022 07:06 - 21 Jan 2022 07:34
The rings will be here today. That was quick.
blog.wiseco.com/everything-you-need-to-know-about-ring-gap
Last edit: 21 Jan 2022 07:34 by SWest. Reason: add link
22 Jan 2022 08:24
23 Jan 2022 11:36
23 Jan 2022 18:10
24 Jan 2022 21:44
- willemZ900
- Z1B 4 ever
25 Jan 2022 03:05
Morning Steve, because you have more compression, how much torque did you use on your cilinderhead? Good luck with your rebuild! Greetings of the cold foggy Netherlands. Willem
25 Jan 2022 06:51
I took it up to 25 foot pounds and will go to 30 before startup.
- willemZ900
- Z1B 4 ever
25 Jan 2022 13:51
APE
26 Jan 2022 12:34
