third gear
- seanj900
third gear
16 Mar 2015 05:24
i just got my 84 900 ninja yesterday took it out for spin and its make a god offull noise in the motor and theres no third and 4th isnt really there either can i do any adjustmant to it
Re: third gear
16 Mar 2015 05:44
Is it possible that your clutch is slipping? What motor oil do you use? Ed
Re: third gear
16 Mar 2015 06:00
If you're lucky it might be your shift drum linkage spring is broken. Is there a cover behind the counter shaft sprocket? You may be able to inspect it there. Remove the clutch/drive chain cover to see. Pics will be helpful too.
- seanj900
Re: third gear
16 Mar 2015 06:06
am running 20-50 all the other gear run fine but the clutch was stuck in it and when i start in neutral sometime it jumps in to gear
Re: third gear
16 Mar 2015 06:25
Do you have a manual?
- seanj900
Re: third gear
16 Mar 2015 06:53
no i dont am just wingin it and not doin a good either i think
Re: third gear
16 Mar 2015 07:31
You need a good one. Maybe someone here will give you a link to the part we're talking about.
- seanj900
Re: third gear
16 Mar 2015 07:44
what a tranny i got a drag tranny and motor in boxes i got i when i bought a parts bike or what do u mean a new a tranny or what and like was saying it making A God offull noise in the bottom its not knockin motor is stong it sound like a bunch of nut and bolt in a metal can being shock real hard
- !Seymore
- Ride on...
Re: third gear
16 Mar 2015 07:55seanj900 wrote: what a tranny i got a drag tranny and motor in boxes i got i when i bought a parts bike or what do u mean a new a tranny or what and like was saying it making A God offull noise in the bottom its not knockin motor is stong it sound like a bunch of nut and bolt in a metal can being shock real hard
Sean, what the heck is this? I can't read it... please use punctuation and type English so we can read it, OK? Hard enuf TRYING to read it, much less understand what you're trying to tell us. Makes no sense to me...
TIA...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Re: third gear
16 Mar 2015 09:05
A broken shift spring will do that.
Re: third gear
17 Mar 2015 07:18
This is the shifting arm and spring on a Z1. They are similar on all models. The little spring on the selector forks might be broken or off and the return spring may be broken as I mentioned before.
- seanj900
