1977 kz650
  • 80B4
  • 80B4's Avatar
Re: 1977 kz650
26 Dec 2014 12:39
#656998
If you want a modified kz650, have the skills needed to finish that one and it comes with a clean title go for it. It will be more work than you think so you will have to spend some money and get your hands dirty.
1980B4 1000
1978 Z1R
1978 B3 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1977 kz650
26 Dec 2014 13:11
#656999
Some people just shouldn't have tools. I'd offer $250 as long as the motor runs. Maybe $300 if it has a battery that will start it. The tail has been cut off, the mounts for the pipes and rear pegs are gone and the upside down triple clamp is the tip off this guy didn't have a clue what he was doing. Parts for eBay.
  • bryce824
  • bryce824's Avatar Topic Author
Re: 1977 kz650
26 Dec 2014 13:16
#657000
Thanks for the info guys. Seems like there is a lot more too it than I have thought, but thankfully I didn't get myself screwed over. I'll keep a lookout for a cleaner not very modified kz!
  • floivanus
  • floivanus's Avatar
Re: 1977 kz650
26 Dec 2014 14:46
#657004
Yep typical cafe bobber fighter crap. There's a few WELL done ones and a bunch of junk out there. My feeling is if you want to build something wacky and wild for YOURSELF then keep your wacky stuff for life, if you do something nice and tasteful that is also reversible then fine to. But obviously, just start whacking at the frame is the order of business here; if it takes a lot of work to start, carbs, ignition or valves arent right, electrical issues? Who knows? Could be harness, switch gear etc.
With the last few bikes I bought without a finished seat that i intended to flip, I also learned them things are a big ole pain to find (78 gs750, and 81 kz1000J, no seats, here, on wbay, craigslist etc) and I had to make new pans, foam and covers, ton of work. Everybike I have bought since then came with a seat.
Past; 78 kz1000, 83 kz550
Andrew
  • DoctoRot
  • DoctoRot's Avatar
Re: 1977 kz650
26 Dec 2014 15:14
#657007
whoa that upside down triple tree is a new level of retardation. I didnt think the bearings would even fit that way.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1977 kz650
26 Dec 2014 17:35
#657030
Where there's a will, there's a way. Sometimes Will isn't around.
Steve :woohoo:
