Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2298
GPZ750, help with front fairing bracket
  • taylee
  • taylee's Avatar Topic Author
05 Dec 2014 13:15
#655423
This little bracket, where my thumb is on, was bent. I need someone to look and tell me what direction or position it should be in.
[IMG
1985 GPZ750 (non-turbo)
  • martin_csr
  • martin_csr's Avatar
Re: GPZ750, help with front fairing bracket
06 Dec 2014 05:41 - 06 Dec 2014 05:51
#655472
The diagram drawing at Partzilla wasn't any help, so I searched the part number on eebbaayy. The item below seems to be in pretty good condition, but you could look at other brackets there for comparison to try to figure out the correct orientation of the tab.
1985 ZX750-A3 fairing bracket --- 11043-1668 --- BRACKET,COWLING BODY
Here's another one which shows a bolt & stuff on the tab.
1983 84 Kawasaki ZX750GPz Ninja Fairing Front Stay Bracket Headlight Mount
Last edit: 06 Dec 2014 05:51 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Dec 2014 06:02
#655476
Fit it to the bike and fairing. That should tell you.
  • taylee
06 Dec 2014 08:55 - 06 Dec 2014 08:56
#655485
Very good. Thanks for the help. DUh, didn't even think about looking at ebay. I think I have it bent back into shape. Apparently my basketcase is missing a headlight adjustment bracket that bolts onto headlight?
Last edit: 06 Dec 2014 08:56 by taylee.
