how to learn more about fixing my bike.
- AjKZBobber
- New KZ rider...Long time dirt biker
Is there a good way to learn this stuff other than basic trial and error. I do want to be able to ride my bike, so I dont want to mess things up really bad in the process of trying to do something minor.
I read lots of posts on this site about all kinds of topics, but the lingo and the technical aspect is pretty much over my head. I am just an average guy with a love of riding, but I also want to be able to do work on the bike myself without messing anything up too badly.
Where do I start? What is the best way to find help? I would love to go to school to learn this stuff, but I dont have the time while working a full time swing shift job.
1979 kz750 b4 twin bobber
- murquiza
- Thank you received: 3
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- AjKZBobber
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- peter1958
- Banned
- Thank you received: 198
- Thank you received: 1656
You'll need a couple of torque wrenches: one in ft-lbs for most of the typical stuff & another one in INCH-lbs for doing the smaller bolts. Use common sense & reference the manual when tightening stuff... you don't need to crank down everything tight w brute force. Torque specs are scattered throughout the manual, but there is also a list in the 1st chapter or thereabouts & there may be a torque spec guidance page for those cases in which there isn't a spec listed.
- bluej58
- Thank you received: 511
What's giving you trouble?
JD
78 KZ1000 A2A
- AjKZBobber
- AjKZBobber
bluej58 wrote: Good to hear from you AJ, you missed the relay.
I didnt get an email notification when you contacted me about the relay. I didnt see the message until a couple days after you came through town. Would have loved to have been there.
I guess the bike has a bare bones wiring setup? Most KZs have a brake indicator/warning light, usually at the tachometer. When the brake is applied, it illuminates. If there's a brake light problem, it flashes.
Starting problem. Be sure to check the battery. It would be good to have a battery trickle charger. I've been using an old Schumacher charger, but I just received a Ctek charger today. After charging, the battery should have at least 12.6 VDC, but a good battery will be higher (~13.1+ VDC). A digital multimeter is handy to have. I use a VC97.... the Robotroom rated it a good one. (eebbaayy ~ $30).
- peter1958
- Banned
- Thank you received: 2098
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do.
Here's how:
