FOUND A SOLUTION Removing Carbon Deposits
- 4TheKZ1000
15 Jan 2014 07:36 - 22 Jan 2014 11:34
Is there a good way to remove tough carbon build up on alum piston tops.
Carb cleaner and a popsicle stick works ok but doesn't get it all.
The carb cleaner evaporates to fast to work good.
The Berrymans carb dip doesn't do anything?
Thanks, Spencer
Thanks, Spencer
Last edit: 22 Jan 2014 11:34 by 4TheKZ1000.
- ZERO
Re: Removing Carbon Deposits
15 Jan 2014 08:34
Carb cleaner and a Scotch Brite pad.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
The following user(s) said Thank You: 4TheKZ1000
- Dr. Gamma
15 Jan 2014 08:43
Place them upside down in some solvent overnight. That gets the carbon to soften up.
A real fine stainless steel brush and some elbow grease..
If that don't work, tape up all but the domes up with duct tape, and find someone to glass bead the domes.
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: wireman, 4TheKZ1000
- 4TheKZ1000
15 Jan 2014 09:04 - 15 Jan 2014 09:14
the pistons are pristine but for the carbon on top, don't want to scotch brite them or mark them up.
I'm seriously considering going to a big block and want to sell the 1075 cylinder and pistons.
Last edit: 15 Jan 2014 09:14 by 4TheKZ1000.
- z1kzonly
15 Jan 2014 09:10
Use 1/4" air grinder with fine 3M roloc scotch wheels. Then glass bead them.
I always glass bead most of my parts.
Attachment sale7.jpg not found
- KZJOE900
- Administrator
Super Users
16 Jan 2014 07:35 - 16 Jan 2014 07:36
+1 on the 3M roloc scotch birte wheels. Although I used it with a drill and with wd40 and not the actual 3M roloc's but I think Harbor Freight equivalents. Works very well at cleaning up old baked on gaskets as well.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 16 Jan 2014 07:36 by KZJOE900.
- ZERO
16 Jan 2014 08:08 - 16 Jan 2014 08:09I don't think a Scotch Brite pad would mark them...even fired from a cannon4TheKZ1000 wrote: the pistons are pristine but for the carbon on top, don't want to scotch brite them or mark them up.
Last edit: 16 Jan 2014 08:09 by ZERO.
- wireman
16 Jan 2014 11:25Now thats funny,i dont care who ya is!ZERO wrote:I don't think a Scotch Brite pad would mark them...even fired from a cannon4TheKZ1000 wrote: the pistons are pristine but for the carbon on top, don't want to scotch brite them or mark them up.
- 4TheKZ1000
Re: Removing Carbon Deposits SOLVED !
22 Jan 2014 10:56 - 22 Jan 2014 11:58
I got those piston tops looking good.
I used 100 grit glass bead media at 20 psi. They look great, and with the low psi didn't do any harm to them.
I did pull rings and wrist pins. I used 2.5 inch blue painters tape to protect the ring grooves and put piston in a old sock before blasting. I gave them a bath in hot soapy water when done, rinsed then very good, blew them out with compressed air and reinstalled the rings and wrist pins. I then soaked each one with WD-40 and put in a clean freezer bag till I'm ready to use.
I found a table top blast cabinet in my area, still in the box on Craig's List for $45.00
I hooked up a cool debris collection device that works awesome.
I riveted a flat piece of metal to lid of can. It separates the can into two halves and acts as a deflector as the debris enters the can, keeping the blast media from just passing though the can.
I then extended the metal plate half way down the can and within 2 inches from the water's top.
Then on the cans lid, one half, closest to the blaster, I punched holes in the lid, the suction of the shop vac pulls air in though these holes......pulling the debris down towards the water before going under plate and exiting the other half of can.
I will put a terry cloth towel on the can top if I exceed 60 psi or up at the gun. It will act as a filter.
It's a solution, but not for all. I had wanted one for years, just got lucky on this one. It is a mess, not much fun.......I still will take big items to my friend and let him do it..
Just waiting for 80B4 to find something wrong or un-safe with it.......... :dry:
Attachment IMG_38811600x878.jpg not found
Attachment IMG_38861600x793.jpg not found
Attachment IMG_38881600x1236.jpg not found
Attachment IMG_3888-Copy1600x746.jpg not found
Last edit: 22 Jan 2014 11:58 by 4TheKZ1000.
- z1kzonly
Re: FOUND A SOLUTION Removing Carbon Deposits
22 Jan 2014 17:50
WTF :ohmy: You'll shoot your eye out kid! :lol:
You need alot finer than that. Get glass measured in microns not grit.
And at least 80-90 PSI
- 4TheKZ1000
22 Jan 2014 18:03 - 22 Jan 2014 18:07z1kzonly wrote: WTF :ohmy: You'll shoot your eye out kid! :lol:
_________________________________________________________________
Your the man z1kzonly........your the freggin man !
:laugh: :laugh: :laugh:
Last edit: 22 Jan 2014 18:07 by 4TheKZ1000.
- Powerstroke_fan
22 Jan 2014 18:14
Are you gonna be sell the 1075 pistons and jugs?
1977 KZ 1000 work in progress
