- Thank you received: 44
Removed my center stand
- jeffasaki
01 Nov 2013 19:01 #611861
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic Removed my center stand
I hire beautiful prostitutes to hold it in just the right position
then fix the bike and go for a ride its the best way to do it
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- bluezbike
- Thank you received: 104
07 Nov 2013 20:25 #612401
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic Removed my center stand
A paddock stand sounds great......but as I have never used one what I would like to see is a step-by-step photo essay of how to put your bike on one. I just don't see how it can be done comfortably with only one person (beautiful ladies of the night notwithstanding) unless it's a side stand on a block of wood first to keep the bike as upright as possible?
79 KZ 1000 LTD
- jeffasaki
07 Nov 2013 23:17 #612416
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Thank you received: 2098
08 Nov 2013 07:03 #612440
by Patton
Replied by Patton on topic Removed my center stand
And for LTD (Living The Dream) owners, there's also the standard biker's pipe option as glorified in the following thread:
Click here > kzrider.com/forum/5-chassis/236039-center-stand#236095
- Thank you received: 2829
08 Nov 2013 07:15 - 08 Nov 2013 07:17 #612442
by 650ed
Replied by 650ed on topic Removed my center stand
Here are a couple different types. Ed
Description of how to use and differences between bobbin vs swing arm type:
Swing arm roll around (pretty cool)
Last edit: 08 Nov 2013 07:17 by 650ed.
The following user(s) said Thank You: bluezbike
09 Nov 2013 08:02 - 09 Nov 2013 08:06 #612609
by 650ed
If you go with a paddock stand please post some pictures so others can see what type you decided on. Some of them look like they would be nice to have even if the bike still had a centerstand. Thanks, Ed
Last edit: 09 Nov 2013 08:06 by 650ed.
- T_Dub
- Thank you received: 25
09 Nov 2013 08:19 #612614
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Removed my center stand
I have a paddock stand made for spools. I just welded on two internally threaded dealies, then screwed in a couple spools I got at the local bike shop. All you do is hold the bike vertical with your hip and get the stand started on the spools, then press down on the back of the stand.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- baldy110
- Thank you received: 512
13 Nov 2013 10:19 #612972
by baldy110
Replied by baldy110 on topic Removed my center stand
