- Thank you received: 5
Removed my center stand
- djturnz
How have any of you that removed your stand found to stand your bike up straight when work is required?
1982 KZ750 (4) LTD
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- KZQ
- Administrator
- Thank you received: 1406
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- 0Z.Z1R Mk2
- Thank you received: 31
- KZB2 650
- Thank you received: 265
KZCSI wrote: Many times the center stand will bolt up but won't fold up. If your bike will bolt up the stand you can just bolt it on when you need to do some maintenance and take it off when you're ready to ride.
Bill
Took my stand off my KZ650 many years ago to save weight and put it on and remove it right away when I need it too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- MDZ1rider
- Thank you received: 118
- slayer61
- KZR FLAG RELAY CARRIER #62
0Z.Z1R Mk2 wrote: What you need is a paddock stand....
A paddock stand is just the ticket. I have 3 or 4 of them in the shop and even a front end stand that supports the bike from the steering stem allowing front end work too
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- zukdave
- Thank you received: 229
Kidkawie wrote: Iunless you're racing.
Funny you said that.
I need to build one that'll work with the wheelie bar.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kidkawie
- I bleed premix
Put a cinder block under the end of it.
1975 Z1 900
2004 KX125
- rstnick
- Thank you received: 377
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
