Winter maintenance on a daily rider?
- isolatoi
26 Sep 2013 17:05 #607913
by isolatoi
Winter maintenance on a daily rider? was created by isolatoi
Hi All,
I bought a KZ650 H2 a month ago and I've been fixing it up doing a lot of general fixes. It's currently my only vehicle going into the winter here in Reno (climate: below freezing nights and 50s in the day with drizzle/rain ~25% of the days; occasional snow which melts in 48 hours). I ride around 30 miles a day with a 100 mile every other week on average.
What would you guys do different from the recommended maintenance to keep this thing in tip top shape through the winter?
Thanks
Thanks
- Thank you received: 2829
26 Sep 2013 18:40 #607920
by 650ed
Replied by 650ed on topic Winter maintenance on a daily rider?
If you're using anything heavier than 10W-40 motor oil now might be a good time to switch over. Anything heavier than 10W-40 will be slow to pump through small oil journals and passages when the engine is cold. You may want to check to air pressure in the tires on a weekly basis if you are not doing so now. Also, make sure the battery fluid level is correct. Ed
- zukdave
- Thank you received: 229
26 Sep 2013 23:47 #607951
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Winter maintenance on a daily rider?
Buy a realy warm coat.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
