What woud you use for luggage!
- Darkangel
24 Sep 2013 21:09 - 24 Sep 2013 21:27 #607646
by Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
What woud you use for luggage! was created by Darkangel
I am stomped...as I am buying another KZ friday, and plan on keeping it original except for the electrical components. I would like to add some type of bags to the bike that would make it look decent. Here is a pic of the bike...I would like yawls opinion on what i should be looking for.
[img size=46.66 KB] images.craigslist.org/00o0o_34BKEHEFXPG_600x450.jpg [/img]
Last edit: 24 Sep 2013 21:27 by Patton.
- Thank you received: 2098
24 Sep 2013 21:30 - 24 Sep 2013 21:39 #607648
by Patton
Replied by Patton on topic What woud you use for luggage!
Sorry, Darkangel, for the unintentional "edit" to your above post. :pinch:
Leather bags look cool, but often aren't fully waterproof.
Hard bags are more of a semi-permanent installation, and sometimes not so visually stimulating.
Supposed to be waterproof. Often a pita.
Throw-over soft bags are serviceable, and some brands are reasonably waterproof.
They're also quick and easy to install and remove.
With any of the bags -- especially throw-overs -- it helps to relocate the rear turn signals.
Examples of rear turn signals relocated onto a simple fabricated metal strip mounted to the tag bracket underneath the license plate.
Last edit: 24 Sep 2013 21:39 by Patton.
- RonKZ650
- Thank you received: 240
24 Sep 2013 23:15 #607674
by RonKZ650
Replied by RonKZ650 on topic What woud you use for luggage!
If you have decent points to tie to, you can just stack bags on the seat behind you. Several waterproof bags out there. I like the Wolfman bags. Tie to the bike with Rok straps that can be even doubled up for more length if needed. I did the USA four corners tour twice and tied 140LBs of bags on the back of my seat.
Great thing is ride with them, take them off when you are done and no ugly luggage sitting empty on the bike.
- Thank you received: 797
25 Sep 2013 16:52 #607748
by 531blackbanshee
Replied by 531blackbanshee on topic What woud you use for luggage!
- slayer61
- KZR FLAG RELAY CARRIER #62
25 Sep 2013 17:33 #607758
by slayer61
Replied by slayer61 on topic What woud you use for luggage!
I try REALLY hard not to ride in the rain, and I like a tank bag
- zukdave
- Thank you received: 229
25 Sep 2013 21:11 #607782
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic What woud you use for luggage!
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Darkangel
26 Sep 2013 00:55 #607819
by Darkangel
Replied by Darkangel on topic What woud you use for luggage!
what do you all think about these?
Nelson saddle Bags
26 Sep 2013 12:11 #607865
by 531blackbanshee
neslon-rigg makes really nice stuff.i wouldn't hesitate to purchase those.
