- Thank you received: 676
Need Kawasaki part diagrams with part numbers.
- Dr. Gamma
24 May 2013 17:15 - 24 May 2013 18:16 #589047
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Need Kawasaki part diagrams with part numbers.
TO YOU ALL AGAIN,THANKS!!!! Got that Kawasaki.com site down pat now!!!
Don't trust that Kawasaki cross reference all the time. Those headlight bezzle mounting bolts are listed as also fitting the H2B and H2C. NO WAY!! If you go to the H2B or H2C parts diagram they are not there!! The H2B and H2C use the stem of the turn siginal to mount the headlight bezzle, not bolts as the H2, and H2A do.I checked couple other parts and they show up fitting a later year of a model bike, but they do not.
If it was me, I would check it out real carefully before I would order or buy certain parts. I checked bikes from the 70's and 80's. They might be right on cross references on the newer model bikes. It still better than nothing!!!
Last edit: 24 May 2013 18:16 by Dr. Gamma. Reason: more info!!
- Kidkawie
- I bleed premix
- Thank you received: 245
24 May 2013 17:59 - 24 May 2013 18:00 #589053
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Need Kawasaki part diagrams with part numbers.
Type this in the model box: H2 (Mach IV)
Shows all the parts and pictures. If you're not seeing photos/diagrams, look for the horizontal page divider that divides the list from the diagram and slide it down.
the parts diagrams don't search well. For instance, you get zero results entering Z1B as a model, you need to have the hyphen: Z1-B
1975 Z1 900
2004 KX125
Last edit: 24 May 2013 18:00 by Kidkawie.
- Dr. Gamma
24 May 2013 18:36 - 24 May 2013 20:11 #589056
by Dr. Gamma
The kawasaki.com website is very very confusing to use. It is NOT user friendly at all!!!
Last edit: 24 May 2013 20:11 by Dr. Gamma.
- Thank you received: 1656
25 May 2013 09:09 #589114
by martin_csr
Replied by martin_csr on topic Need Kawasaki part diagrams with part numbers.
The Kaw site isn't perfect but certainly better than nothing. What I do is use the Partzilla diagrams to do most research, then verify the info as best I can at Kawasaki.com, especially before buying something. ebbaayy photos are often times helpful for figuring out some stuff.
- boatdrinks
- Thank you received: 54
25 May 2013 09:50 #589117
by boatdrinks
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Replied by boatdrinks on topic Need Kawasaki part diagrams with part numbers.
I find dealercostparts.com to be very user friendly and it does have the ability to do a cross reference for parts numbers and the models they were used on.
Charles
Madison, AL
