- Thank you received: 2
went down...
- jacksdad
- 1979 kz 750 OUCH, IT SPARKED
anyone know where i can get a clutch handle for a 79 kz 750, also need to know if replacement brake hoses can be made somewhere, i got new bars from a virago, which are a little taller, can't seem to get the handle in a comfortable position without overstretching the hose. thanks..
1979 kz750 twin cyl.
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Thank you received: 2098
Would look at Z1 Enterprises.jacksdad wrote: :silly:
Click > www.z1enterprises.com/ListItems.aspx?key...e=Body&advanced=true
Click > www.z1enterprises.com/ShopByCategory.asp...&category=0102011201
- dav231481
- jacksdad
- jacksdad
kawasaki.com shows upper brake hose part no. 43059-007 for 1979 KZ750-B4, which is listed at Z1E:
Click here > www.z1enterprises.com/ItemDetails.aspx?i...50+Z1&item=PM81-3071
A search at Z1E for 43059-033 produced no results for the lower brake hose. But, I would suspect that the lower brake hose, or a suitable substitute, is available at Z1E.
If needed, here's a link for help with navigating kawasaki.com and finding information.
Click here > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
When in doubt, would contact Z1E for further info.
- jacksdad
- jacksdad
