J Block on KZ cases
- LarryC
08 Apr 2012 06:40 - 08 Apr 2012 06:44 #514662
by LarryC
Larry C.
J Block on KZ cases was created by LarryC
It's common knowledge that you can't put a J model block on KZ cases. Well, someone forgot to let Max at Performance Engineering in Nashville in on that deal :laugh:
Here's a KZ with a 1260cc GPz1100 top end. The owner is a customer of mine. I did the head and Max did the rest of the work. Super nice guys, both of them. It's got a set of Jay's K435 cams & buckets with RS36 carburetors. Tons of torque everywhere according to the owner. Anyway, nice clean, well done.
Attachment imagejpeg_2.jpg not found
Larry C.
Last edit: 08 Apr 2012 06:44 by LarryC.
- Powerstroke_fan
- Thank you received: 83
08 Apr 2012 09:33 - 08 Apr 2012 09:34 #514674
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic J Block on KZ cases
Thats a sharp bike, so larry what all would go into making that top end fit and work on the bottom end??
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 08 Apr 2012 09:34 by Powerstroke_fan.
- roy-b-boy-b
- Thank you received: 103
08 Apr 2012 09:51 #514675
by roy-b-boy-b
Replied by roy-b-boy-b on topic J Block on KZ cases
That is a sharp bike. Roy
- zed1015
- Thank you received: 1551
08 Apr 2012 12:09 #514698
by zed1015
Two ways of going about that.
Keep the roller crank ,Ape idler for the head, barrel spacer and machine the block for the idler wheels + a few other small details or slightly easier - fit a J/GPZ crank and adapt the crankcase to take the lower end of the front camchain slipper.
Replied by zed1015 on topic J Block on KZ cases
Powerstroke_fan wrote: Thats a sharp bike, so larry what all would go into making that top end fit and work on the bottom end??
