- Thank you received: 28
Horrible maintanence tips from Tim
- TeK9iNe
- What did you do!?!
Kitten Tooth wrote: If you battery has a low charge and it only "clicks" when you hit the starer button, Take the terminal that would normally be for the negative post and bolt it to the positive post. When you move the positive terminal to the negative, you should see a good spark when you touch the wire to the post. Let it sit like this for a few hours and any residual charge that was left in the harness with be directed to the battery. This works every time.
Ahaha! :woohoo:
Make sure to do this in a nice air tight location, and dont forget to enter with a lit cigarette in your mouth! :blink: :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2829
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- Kitten Tooth
- Thank you received: 10
Proxy wrote: Regrinding the valves often gives new life to old engines and can even add 10-15 hp to new engines but most are intimidated by even the sound of it. Never fear it's not as hard as you think. Go to the local automotive store and ask for valve grinding compound. It's pretty cheap and a little goes a long way. Just a couple of tablespoons in your gas and about 3 teaspoons in your crankcase then run it like you stole it for about 20 miles. This will polish it's innards like a mirror. You won't believe the difference. This tip was brought to you by Acme Engine Re-Builders 201 HiRev Drive Quaker, VT 04245 555-55-555 Ask for Vic :evil:
Oh no
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
"If it doesn't start on the first kick, Give up."
so very simple and WRONG!!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
DUMP SUGAR IN YOUR GAS TANK.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Kitten Tooth wrote: Not even trying with this one..
Pure sugar doesn't contain enough energy to give the engine the boost it needs; guys that really know the secret tips always use this:
Attachment NOS.jpg not found
not.
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- KZ250LTD
- Thank you received: 16
