Horrible maintanence tips from Tim
  • Kitten Tooth
  • Topic Author
17 Jan 2012 06:40 #498426 by Kitten Tooth
Horrible maintanence tips from Tim was created by Kitten Tooth
Ok, first off... To anyone actually looking for help on this forum
> FOR THE LOVE OF GOD DONT DO ANYTHING THAT IS LISTED BELOW :sick:
I thought it would be funny as hell to make a list of aweful ways to maintain your car or motorcycle so here it goes.
- It helps to add a bit of sand to your gastank and remove any fuel filters that maybe be inside, or inline for the fuel supply. Adding sand can greatly improve your motorcycle's ability to have properly lubricated cylinders. Less compression=Less friction+Easier
movement with the pistons in the cylinders.
-If you have a motorcycle with Constant velocity carburetors, take the top caps off of the carbs. Then take a needle and poke 3 holes in each of the diaphragms. This will enable fuel to spread throughout the carburetor better which enables your cylinders to pull fuel better.
-A good way to make your overhead cam motorcycle or car run better is to remove the valve cover and loosen the cam chain tensioner. Then Give the chain a good pop with your hand to make it loosen off of the guides. After you have done this, pull the chain away from the cam sprokets or pullies and rotate the cam about half a turn. Do this with both cams. Then let the cam chain sit back down on the sprockets and re-assemble. You do this because the factory service repair manual is 100% incorrect on how you do the timing on your bike. Its better if you just guess. If you follow the instructions in the manual your timing will be wrong and you will bend your intake and exhaust valves.
-A very good way to make the gears spin faster in your Differential (on rear wheel drive vehicles) is to pull the cover off of the differential. Let all the fluid drain out and gently remove the gears inside. Throw them away. Put the cover back on. Differentials are magical and do not require gears to function.
-A good way to clean the rust out of the gas tank in any vehicle, is to remove the gas cap. Then insert 20-30 marbles into the fuel hole. After you have done this, add bleach to really get rid of all the germs inside the gas tank. Remove any fuel filters and re-assemble. Drive the vehicle like this for the rest of the time you own it.
-After any engine rebuild, make sure that your regular operating speed during engine break in is at least above 8500 RPM. If this is an Aircooled motor, make sure that the vehicle is not moving anywhere. If the motor is watercooled, make sure you drain the radiator of its fluid and run the engine like this for a minimum of 30 minutes. This will help the rings seat better.
Once again.. dont do anything in this list :laugh: Dont know if this type of think is a no no on this forum but i thought you guys might think its funny.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
17 Jan 2012 11:13 - 17 Jan 2012 11:20 #498439 by 650ed
Replied by 650ed on topic Horrible maintanence tips from Tim
:laugh: It is funny! Sadly, some owners have done nearly everything you described. Another fine tip is to hacksaw off the exhaust headers about 5" down from the cylinder head. This will reduce backpressure and add about 50 horsepower to any gasoline engine (be careful doing this to a little KZ200 because the extra 50 hp may be too much for the frame). Oh, and don't forget, remove all air filtration (stock or pods) from the carbs - that filtration just slows down airflow and reduces power - plus, it isn't needed because air is pure and clean (heck, that's why it's invisible)! Ed
Last edit: 17 Jan 2012 11:20 by 650ed.
  • Kitten Tooth
  • Topic Author
17 Jan 2012 17:38 #498480 by Kitten Tooth
Replied by Kitten Tooth on topic Horrible maintanence tips from Tim
650ed wrote: :laugh: It is funny! Sadly, some owners have done nearly everything you described. Another fine tip is to hacksaw off the exhaust headers about 5" down from the cylinder head. This will reduce backpressure and add about 50 horsepower to any gasoline engine (be careful doing this to a little KZ200 because the extra 50 hp may be too much for the frame). Oh, and don't forget, remove all air filtration (stock or pods) from the carbs - that filtration just slows down airflow and reduces power - plus, it isn't needed because air is pure and clean (heck, that's why it's invisible)! Ed
HAHAAA :laugh:
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • TeK9iNe
  • What did you do!?!
17 Jan 2012 18:58 #498487 by TeK9iNe
Replied by TeK9iNe on topic Horrible maintanence tips from Tim
:laugh:
The farther you advance your ignition the more horsepower you can add to your engine!
Just rotate your ignition plate as far counter-clockwise as possible, thus ensuring maximum power.
The louder she bangs the faster she'll go!
:laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
17 Jan 2012 21:12 #498509 by jeffasaki
Replied by jeffasaki on topic Horrible maintanence tips from Tim
dont forget the "just throw some saw dust in with the oil"
thatll stop it smoking
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • Kitten Tooth
  • Topic Author
18 Jan 2012 00:06 #498540 by Kitten Tooth
Make sure you load the cylinders up with as much starter fluid as possible. You do this on rebuilt motors when first starting them to ensure maximum performance.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
  • Topic Author
18 Jan 2012 00:07 #498542 by Kitten Tooth
A good way to prevent your clutch plates from slipping is to over tighten your clutch cable. It may feel like the clutch is not all the way engaged on your first ride but it will get better.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
  • Topic Author
18 Jan 2012 00:09 - 18 Jan 2012 00:10 #498545 by Kitten Tooth
If you have leaky fork seals, take a hand drill and put two holes in the bottom of each fork. Make sure you have a pan of some sort to catch any oil that may come out. After you have done this, put a bolt in each hole you drilled and your done. There is no way to repair leaky forks.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 18 Jan 2012 00:10 by Kitten Tooth.
  • Kitten Tooth
  • Topic Author
18 Jan 2012 00:14 #498547 by Kitten Tooth
When replacing a valve cover gasket, make sure you use gasket sealant around the whole gasket surface but not on the cam end caps. While tightening down the bolts (if you do not have a torque wrench) Crank each bolt with a socket wrench about 15 times from hand tight.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
  • Topic Author
18 Jan 2012 00:17 - 18 Jan 2012 00:18 #498551 by Kitten Tooth
jeffasaki wrote: dont forget the "just throw some saw dust in with the oil"
Good god, i wouldnt even do that on a crappy old lawnmower XD
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 18 Jan 2012 00:18 by Kitten Tooth.
18 Jan 2012 02:44 #498596 by elfmagic17
Replied by elfmagic17 on topic Horrible maintanence tips from Tim
The best way to get Maximum power is to take the carbs off and just run 4 fuel lines directly into the intake ports, this acts like a supercharger and you don't need those pesky throttle blades or slides anyways!! :P Oh and don't forget to run 117.5 to 1 compression on that supercharged turbo powered engine, the more compression the better. Just use a little loc-tite on the head nuts or the head may separate from the block. :woohoo:
Kenny Hicks
74 Honda CB550
  • Kitten Tooth
  • Topic Author
18 Jan 2012 04:12 #498605 by Kitten Tooth
If you battery has a low charge and it only "clicks" when you hit the starer button, Take the terminal that would normally be for the negative post and bolt it to the positive post. When you move the positive terminal to the negative, you should see a good spark when you touch the wire to the post. Let it sit like this for a few hours and any residual charge that was left in the harness with be directed to the battery. This works every time.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
