- Thank you received: 12
MID-KNIGHT: Tokyo Z-1 custom shop
- WPBill
The shop is only about 20 miles away from my house as the crow flys, but actually getting there via roads is difficult. Took me three and a half hours to get home last night! All the major roads were choked with traffic, so I got home using side roads so narrow I had to fold my door mirrors in to clear oncoming traffic.
Kaneko-san himself with your humble scribe.
This is a Ninja he was working on. See the robust side brace?
It actually incorporates a ram air system.
Other side of the bike, which features a heavy duty cooling system.
Kaneko-san hand cut the flames on a band saw.
Also hand tooled the ribs on the thermostat housing.
Likewise hand detailed the instrument panel.
The start of a Z-1 based project. The FRP seat/tailpiece is a MID KNIGHT original.
While the short version of Mid Knight's motto is "Built For Speed" this is the longer one.
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
- WPBill
Note the modified intake manifold, upturned to keep the fuel bowls from starving while the owner pops a long distance wheelie.
Modified oil system to ensure the heads receive cooler oil.
Braced swingarm since the owner spends so much time on the back wheel alone. Ignore the sticker on the megaphone, the 4/1 is actually a MAC, although MID KNIGHT does produce its own 4/1 systems.
MID KNIGHT crafted vented sidecovers, the modified emblems are also MID KNIGHT originals.
And his trademark timing covers. This is an early sand cast (!!!) version he had lying around the shop, his current ones use a better manufacturing process. He told me what it was, but I forgot.
- Chaotic Reason
- Thank you received: 15
Michael
1980 KZ1000 shaft drive
- Mcdroid
- Gone Kwackers
- Thank you received: 316
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Thank you received: 797
how long are you going to be back in japan?
- Thank you received: 2098
WPBill wrote: ... Note the modified intake manifold, upturned to keep the fuel bowls from starving while the owner pops a long distance wheelie.
Nice work abounds.
Could be wrong, but thinking fuel bowls would be tilted forward instead of backward to maintain fuel level orientation during extended wheelies.
Perhaps the carbs at hand are from some other bike's engine with a more down-draft carb design where bowls are slanted to remain more level in compensating for the down-draft fitting of the carbs.
- WPBill
531blackbanshee wrote: bill thanks for posting!
At least another two years.
- WPBill
Patton wrote: Could be wrong, but thinking fuel bowls would be tilted forward instead of backward to maintain fuel level orientation during extended wheelies.
I dunno. Liberal arts major, here.
- JR
- Thank you received: 445
You always post the most interesting stuff
