- Thank you received: 12
Possibly returning to the forums! (with a KZ750E1)
- clutch
- I wish I had a tad more patience to do it better!
~Clutch
EDIT: This is what mine looked like when I picked it up...yours is in WAY better shape!
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- Thank you received: 2098
DivideOverflow wrote: ...anyone know what universal backrests may fit? I'm looking for a small one, not the 3 ft tall ones. My wife doesn't like to ride without one.
DivideOverflow wrote: ...Anyone know if there are gaskets that fit the cross pipe?....
Per kawasaki.com, the gasket is part no. 11060-1051, and remains "active," meaning it's still available through Kawasaki dealerships.
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
- Motor Head
- Thank you received: 391
The best racks and back rests I've found have been local through Craigs List. Although Feebay does have quite a few. I like the K&G rack with adjustable Back Rest/ Sissy Bar, it has a clamp on each side so you can slide the bar forward or backwards.
- DivideOverflow
The only functional issue other than the exhaust leak is the clutch cable needs a good cleaning/lubing. Ill probably do the throttle cable while I'm at it.
I hope that back rest looks decent, it is hard to tell from the pictures what it looks like on the bike.
1980 KZ750E1
North Carolina Crew
- Motor Head
- DivideOverflow
I just saw a picture of a harley with that backrest I bought on it... looks too raked back. Ill have to see when I get it, and ill need to get a pad for it.
1980 KZ750E1
North Carolina Crew
- JR
- Thank you received: 445
Picture looks a lot better than it really is. A lot of not stock - read salvage yard - parts like chain guard, mirrors, turn signals, airbox etc + oil cooler and a recovered seat. One of these days I'll pick up a chrome 4->2 exhaust.
- DivideOverflow
Did anyone have an answer on how to fix one of my rear shocks? The top adjuster spins freely, and doesn't actually change the value.
1980 KZ750E1
North Carolina Crew
- JR
DivideOverflow wrote: ..............Did anyone have an answer on how to fix one of my rear shocks? The top adjuster spins freely, and doesn't actually change the value.
One of my shocks has always been like that. I just leave the shock on the highest setting. If I ever need to change it I have a strap wrench I can use. I think my best solution would be to buy a new pair of shocks.
- DivideOverflow
Now I have half a mind to go through the carbs to check up on what he did (said he just did a carb kit to stock specifications). It is a little slow to warm up, but seems to run fine once warm. I guess I should invest in a carb sync tool and at least make sure they are synced.
Considering my bro has a CB900, we could both use it.
1980 KZ750E1
North Carolina Crew
- Motor Head
Have a look at this.
www.kzrider.com/filebase/doc_download/18...fferential-manometer
Super easy to build, and works very well.
