- Thank you received: 43
Anywhere to have some aluminum cut?
- 79MKII
- Love Them Kaws!
I'm looking to make a custom tail light bracket / license plate / turn signal bracket. I have a template made and would love to have somebody cut it out on a machine. Isn't there somewhere I can send it? It seems like there would be a web site in this day and age where one could have just about anything made. From what I've seen a plasma or water-jet cutter could do this in 5 minutes. It needs to be make out of aluminum plate around 1/8" thick. Actually could be any material/thickness strong enough to hold a plate and a set of turn signals.
I can cut this myself but it would look a lot better if it were done professionally. I'd have to use all hand tools....no drill press or band saw, etc...
Any ideas?
This is what I had - 2 pieces - the plate bracket broke after 950 miles. I thought a new one piece unit would be great.
(view from underneath):
And how it looked before it broke:
The Kaw List:
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- wireman
- Thank you received: 299
- hocbj23
- Visitor
- 79MKII
- Love Them Kaws!
hocbj23 wrote: go over to "do the ton.com" and look up a guy named swagger.He does custom machine work and does it well.bj
I have to register to search anything....I'll look into it.
In the mean time, I just found www.emachineshop.com You download free software, design your part, and get a price. I'll try to get the part drawn up this weekend and see how terribly expensive it will be.
The Kaw List:
- 79MKII
- Love Them Kaws!
The Kaw List:
- 79MKII
- Love Them Kaws!
The Kaw List:
- wireman
- jonnybravo
- Banned
- Thank you received: 18
- wireman
- cavanaughracing
- Banned
79MKII wrote: Messed around a little today with the cad program. Here are the 2D and 3D versions:
Nice job on the CAD drawings
I know a couple of people that use their service. It's a volume based deal for pricing. More = cheaper. Might be worth your while to see what 5 would cost and ebay the other 4 or put them in the for sale section here...... just a thought..
Larry C.
cavanaughracing.com
- 79MKII
- Love Them Kaws!
Wireman - As far as the stainless steel, what thickness would you recommend? I'm sure it would be thinner than the aluminum, right?
Larry - I was thinking the same thing...order 4 or 5 and try to sell a few on eBay. The biggest problem I see is that some people might not want the 45 deg bend for the license plate. I might have them made straight and then bend mine myself. Mine's a little different since I have an extended swingarm - I need to bend it to clear the tire.
The Kaw List:
