- Thank you received: 675
Differnet way to remove emblems from engine covers
- DoctoRot
14 Jun 2011 18:17 - 14 Jun 2011 18:18 #457278
by DoctoRot
Differnet way to remove emblems from engine covers was created by DoctoRot
I wanted to spiff up my engine covers since the stator has some road rash and the paint is coming off. I decided to remove the emblems them because I never was a huge fan of them anyway, and it already says Kawasaki 3 other places.
Im sure there Are other ways of doing this that are easier/better, but I wanted to use the tools I already had.
I started off by grinding off the emblems so that the top of the points and stator cover were flush.
Then I dragged my potters wheel into the garage and centered the stator cover on the wheel.
Holding the cover firmly in place i pressed a water based clay around the perimeter of the case. If you use enough clay you will be surprised how firmly it holds this in place.
Next I put a 80 grit flap-wheel on my angle grinder, and set the wheel speed to high.
The outside edge is the most important factor in determining the profile so i started there. It was uneven, so holding the grinder to the edge I locked my arms and kept the grinder absolutely still. I focused on keeping the tool as still as possible letting the tool do the work. If you do this right you will get a nice even edge. Once the edge was established I started very very slowly moving the grinder towards the center of the wheel. This is done in a similar way to how you would move a cutting bit on a lathe. Over the next 15 minutes I slowly worked outside to in and back out, removing material until a even profile was present. I then cleaned the bevel up a bit as well. The out come is something that has a nearly perfect profile and almost looks machined.
I repeated this process on my points cover, and started polishing the top.
From here you can either paint or polish. I will probably do a combination of both.
Hope someone finds this helpful
Last edit: 14 Jun 2011 18:18 by DoctoRot.
- Kidkawie
- I bleed premix
- Thank you received: 245
14 Jun 2011 22:20 #457311
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Differnet way to remove emblems from engine covers
Definately original! Haha!
1975 Z1 900
2004 KX125
- wireman
- Thank you received: 299
15 Jun 2011 00:43 #457347
by wireman
Replied by wireman on topic Differnet way to remove emblems from engine covers
be carefull grinding on stator cover,theyre a little thinner in the center than around the sides
- Thank you received: 797
15 Jun 2011 10:57 #457400
by 531blackbanshee
Replied by 531blackbanshee on topic Differnet way to remove emblems from engine covers
one tool holder away from a lathe :woohoo: !
you could polish up the edges of some mags like that also :lol: .
