- Thank you received: 225
The best way to rust proof your bike. idiot?
- Old Man Rock
Note lips demeanor/expression... Lips all squished tightly, butt is puckering would be my guess. :ohmy:
NOTE to Thyself When @ Craig's next year.... Don't let him inflate my tires.... :whistle: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Zedone
- Thank you received: 14
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- steell
Beard wrote: also i have sat there all night trying to figure out the new old bike i just picked up would let the rear tire spin while it was in gear.. finally i realized the bike didnt have a chain!
I stand humbled in the presence of greatness
I retire as a defeated champion :blush:
- OregonMatt
1976 kz 900
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
Forgotten fill cap rustproofs the right side,
trying the starter without the stator cover in place to admire your handy work of rebuilding a 750 twin starter clutch takes care of the left side.
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
- wireman
- Thank you received: 299
no that one wasnt me! :woohoo:
- wireman
anyway i helped with part of the assembly of his 900ltd anyway he calls me up after hes put about 500 miles on it cruising the mountains.
says when he stops the front end acts really funky! :sick:
since i rebuilt the front brakes for him i drove down there to take a look at it :blink: so i drive it around the block and realized immediately something was really wrong,come back to his house and jack it up and you can push/pull the entire front end band forth front to rear! :sick:
i proceed to strip the whole frontend off of bike in about 15 minutes,the look on his face after he just spent 2 years putting it together was priceless! :woohoo:
come to find out after he had frame and triple trees powder coated and new tapered bearings pressed on he installed them without installing bearing races in steering head. :sick: :dry: :huh: :blush: :S :blink: :ohmy: :whistle:
so anyway i made an install tool from a piece of all-thread some fender washer a couple nuts and 2 pvc pipe fittings and got it all back together,also dumped that damn 10w fork oil and replaced it with 30w synthetic motor oil and 2 new fork springs i had laying around.
had front end rebuilt and bike up and running down the street in under 2 hrs,he told me it took him 6 months to put the frontend back together and i did it faster than he could bolt the front wheel on!
the next day i installed pull down steps into his attic! :laugh:
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
Took my clutch apart, inspected the friction plates, steel plates, measured thickness, etc. Everything looked great. Then I discovered that the whole problem was the pushrod clearance adjustment on the left side cover of the bike. I could have done this in 5 minutes on the road if I had just known about it. Before the trip, I had not had the bike that long, and read about it in the manual, but the nut was corroded onto the adjustment screw, so I thought I better "leave well enough alone". If I had only known!
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- Beard
79 KZ650B
Jack of everything, Master of nothing.
- Marneman
- Thank you received: 5
Sold for some good coin on ebay though :laugh: Used the cash to buy another corroded one so I could do it all over again. This one at least fits though
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- Kitten Tooth
- Thank you received: 10
Installed Kerker 4 into 1 and left stock jetting. I thought the sound of firecrackers going off behind me sounded cool. Rode it all summer like that. Fail.
Screwed in flywheel puller to remove flywheel when my starter clutch came loose. Flywheel puller stuck out about 5 inches after being threaded in. went to mindlessly put my bike on its side stand without the engine cover on. Oil dumps everywhere. Then i slip and drop my bike right on its side with the puller sticking out so a good 5-600 pounds of weight is being put on the crankshaft. <
that one was the worst.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- baldy110
- Thank you received: 512
