- Thank you received: 11
Alcohol KZ?
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- Kitten Tooth
- Thank you received: 10
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- mtbspeedfreak
- Thank you received: 36
mtbspeedfreak wrote:
Kraz, do you know those guys?
The custom aluminum airbox with the cylindrical K&N filter on the 900 is downright stunning!
Injected is a member here and on CM. Projects Links below.
AirBox
Check Out the Billet Block Project as well...
I fixed the Links.
Thanks! Did he write up how he crafted the airbox, or did I miss it? That's one of the coolest ideas I've encountered on here!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- z1kzonly
- Thank you received: 538
You ever get one running, you might as well try some NITRO in it too! :woohoo:
NITRO methane is the 8th wonder of the world!
- Lorcan
- Speed Loony
- Thank you received: 59
Only synthetic oils most be used, specificaly poliester oils only and all seals must be changed.
That would be the complete opposite of my advice. I lost two turbos and a crank to synthetic oils. I've never had a problem with mineral oil in my 750s and we use mineral oil in Storm too.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Lorcan
- Speed Loony
760cc - 8.69@162mph
- gearheadmm
I don't think it detonated, it looks like high EGT, lean, did it. See how it started near the exaust port. Probably started near half track and once that piston started melting did the damage very fast. Imagine all that aluminum stuck to the turbine wheel, very expensive lesson.i died laughing at thisXDDDD thats so aweful!! did it blow up or somthing like halfway through the race? He copensated for the loss of compresstion with sugar!!
- Injected
The factors that prevent it from being run on the road effectively :
Fuel economy
Cylinder wash down
Oil contamination
Corrosive nature of the fuel
It runs best when its fuel injected in a high compression motor with a lot of ignition lead - these are also some factors preventing its effective use on street ridden motorcycles.
I have not had any issues with seal swell because I purge my fuel system after each use then flush with lubricant... if you want your equipment to last this has to be done as soon as its parked - you really have to love wrenching on your stuff to even think about doing this conversion.
We use a low cost straight weight oil and dump it after the days running and from what I have seen that alcohol will not seperate from the oil within 6-8 months... even the oil trapped up in the cylinder head has alcohol in it.
We save the oil and reuse it in the lawnmower and snow blower... pit bike, etc.
