Engine Case Cleaning
19 Dec 2010 20:54 #417819 by Marneman
Engine Case Cleaning was created by Marneman
Hi Everyone, Looking for any tips regarding cleaning an enigine case. I have a complete engine that is out of the frame, but it is nasty dirty. I've read some about soda blasting but am not sure whether that would be the right call on a complete engine. Any advice would be greatly appreciated.
Thanks.
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
  • stonemaster
  • Visitor
19 Dec 2010 21:04 #417821 by stonemaster
Replied by stonemaster on topic Engine Case Cleaning
I just finished doing mine, I used a engine degreaser on it first, then i used VHT paint stripper and then went over it with VHT case paint, looks great, I've soda blasted carbs before but didnt really need to for this, check the budget soda blaster thread for more info on that
19 Dec 2010 22:13 #417829 by Marneman
Replied by Marneman on topic Engine Case Cleaning
Thanks for the info stonemaster! I took your advice and checked out the soda blaster thread. Coolest idea I've seen in awhile. Can't wait to try it. Think I'll lug it to the car wash first and give it a good hose down. Maybe a spray down with gunk would be in order too. Thanks again Bro.
  • stonemaster
  • Visitor
19 Dec 2010 22:38 - 19 Dec 2010 22:40 #417833 by stonemaster
do not pressure wash, rinse gently after degrease (gunk), I used vinegar and water in a spray bottle, with engine together never wash with high pressure
Last edit: 19 Dec 2010 22:40 by stonemaster.
  • kz1k
  • You Cant Fix Stupid!
20 Dec 2010 00:28 #417840 by kz1k
Replied by kz1k on topic Engine Case Cleaning
is this because the motor is still together? my cases are split, and was told by many members here to take them to the car wash...which i did.
as for the diy budget soda blaster. i have a 15 gall, decent size compressor. it took forever just to do my oil pan. i will either grit my teeth and finish the same way, or pay a machine shop to soda blast em.....joe
1978 KZ1000A2
  • stonemaster
  • Visitor
20 Dec 2010 00:52 #417844 by stonemaster
if its apart then .. i thought it was still together, sorry, pressure washing can blow out gaskets, no gasket no problem
  • kz1k
20 Dec 2010 00:56 #417846 by kz1k
dont be sorry, from the jist i got his motor is still together.:)
1978 KZ1000A2
  • stonemaster
  • Visitor
20 Dec 2010 01:03 #417848 by stonemaster
ok man B)
20 Dec 2010 13:13 #417905 by big mike
Replied by big mike on topic Engine Case Cleaning
i have a sand blasat cabenet i use glass beads ( on disasembled motor) a motor that is together you can use walnut shells it makes the thing look brand new the trick is to find someone who does it
  • stonemaster
  • Visitor
20 Dec 2010 14:02 - 20 Dec 2010 14:03 #417916 by stonemaster
dont need a cabinet, Harbor Frieght has beads and shells, air gun and hopper for $29.00 I got some beads, havent tried the shells yet, if ur worried bout stuff flying everywhere get a big ass cardboard box and some duck tape, worked for me
Last edit: 20 Dec 2010 14:03 by stonemaster.
20 Dec 2010 15:11 #417922 by Patton
Replied by Patton on topic Engine Case Cleaning
big mike wrote:
...i use glass beads ( on disasembled motor)....
For consideration--
Many well-qualified folks recommend against any glass bead ever touching the inside of an engine or any of the internal parts.
Because getting all the glass beads removed borders on the impossible.
Good Fortune! :)
  • z1kzonly
20 Dec 2010 15:54 #417930 by z1kzonly
Replied by z1kzonly on topic Engine Case Cleaning
I've been glass beading parts for over 30 years!
Transmissions, cases, heads.
Yes it is alot of work, but it can be done!
Of course I always thread bolts into any holes and tape oil galleys.
I always wash in hot soapy water with air agitation too.
And 3 and 4 times!
