- Thank you received: 391
my kz 550 ltd is here
- Motor Head
08 Aug 2011 21:00 #467817
by Motor Head
Replied by Motor Head on topic my kz 550 ltd is here
That's good, try to see if you have leaks. That's most likely the next check to do anyway. Another issue on them is lost voltage along circuits, starting with the main fuse at the fuse box. I don't know if you have been through the wiring? Low charging voltage, low coil voltage, and low headlight voltage can be traced back to the Fuse box and harness there. Pretty common.
- ditchdriver
08 Aug 2011 21:03 #467818
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
Replied by ditchdriver on topic my kz 550 ltd is here
actually the headlight is pretty bright and it turns over pretty easy it just wont stay running
1982 kz 550 ltd
Grand Forks, ND
- Motor Head
08 Aug 2011 21:06 #467822
by Motor Head
I just meant that these are issues that could be Other problems that could effect your 550. I'd look for the Vacuum leaks, before going back in the carbs. If you do get into the carbs see member Loudhvx posts. he has a web site set up for the 550. Lots of good info there.
- ditchdriver
08 Aug 2011 21:08 #467823
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
cool thanks i might look at that anyway just to see what info he has there
1982 kz 550 ltd
Grand Forks, ND
- ditchdriver
09 Aug 2011 20:09 #468074
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
found the culprit i had the vacuum hoses on in the wrong spots
instead of having the hoses on the mounting boots for the carbs i had the attached to the carbs themselves.
ok so another inquiry from the great minds is idleing at 2k good or bad it sounds a little much to me but i am a newbie. i ran out of adjustment on my idle screw so ive got to make another few tweaks. but i did have it ideling without me touching it and i never had to mess with the choke so i think that problem is solved.
1982 kz 550 ltd
Grand Forks, ND
- Motor Head
09 Aug 2011 22:10 #468094
by Motor Head
Did you check you throttle cable to see if it still had slack? 2K is a bit much, 1K would be more like it.
- ditchdriver
27 Sep 2011 10:57 #479931
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
the beast has come to life finally. took it for a small ride works great idles good just needed a little help getting it started
1982 kz 550 ltd
Grand Forks, ND
- ditchdriver
21 Feb 2012 20:52 - 21 Feb 2012 20:52 #505546
by ditchdriver
new pic with sissy bar and saddle bags gonna be riding it as soo as it warms up come on summer
1982 kz 550 ltd
Grand Forks, ND
Attachment 0221121601.jpg not found
Attachment 0221121602.jpg not found
1982 kz 550 ltd
Grand Forks, ND
Last edit: 21 Feb 2012 20:52 by ditchdriver.
- mtbspeedfreak
- Thank you received: 36
21 Feb 2012 22:26 #505559
by mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
Replied by mtbspeedfreak on topic my kz 550 ltd is here
Nice! An LTD550 was my first set of two wheels!
2000 ZRX 1100
