- Thank you received: 21
where to get oil pressure gauge?
- AtLarge
10 Feb 2010 18:23 #347633
by AtLarge
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
Replied by AtLarge on topic where to get oil pressure gauge?
1973 Honda CL70-K3
1994 BMW K1100RS
- 9am53
- homebrew, and some bbq
- Thank you received: 3
10 Feb 2010 18:26 #347635
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic where to get oil pressure gauge?
I thought these bikes got like around 2 or 3 psi...
'84 GPz900r
'71 CB350
- AtLarge
10 Feb 2010 18:58 #347641
by AtLarge
1973 Honda CL70-K3
1994 BMW K1100RS
Well, that's what I've read but I dunno...
This shot is with the cover off and the motor running but stone cold and a fresh filter. Once it warms up it drops down. It's an Autogauge brand meter 0 to 100psi. I tried a 0-15 gauge the first time but it consistently pegged the needle.
1973 Honda CL70-K3
1994 BMW K1100RS
- Thank you received: 2098
10 Feb 2010 19:44 #347658
by Patton
Replied by Patton on topic where to get oil pressure gauge?
9am53 wrote:
Kaw large fours (with needle bearing cranks) have the low psi.
AtLarge's bike is a KZ750 twin, which has higher psi.
Good Luck!
Good Luck!
- ArthurGoVroom
- I'd rather ride it than shine it
10 Feb 2010 20:07 #347663
by ArthurGoVroom
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
Replied by ArthurGoVroom on topic where to get oil pressure gauge?
I got a pressure gauge from Mcmaster.com as posted above. It is one of the 1.5" diameter gauges with the pipe thread nipple coming out of the bottom of the gauge. I used a tapered pipe bushing (i believe 3/8" NPT size) in the oil pressure test port in the block with red loctite on it to seal and secure. The thread pitch just so happens to be the same as the metric threads in the block, but the threads in the block are not tapered. The red loctite is required to take up the difference in size because I believe it would be too loose for teflon tape or liquid pipe sealant. I screwed the gauge in so that it was facing toward me when I'm sitting on the seat, I can glance down at it and see the oil pressure while riding. I used a 0-30 psi gauge, it will peg the gauge if you rev the engine high while cold but you shouldn't be revving the engine high while cold anyways I've ridden about 1000 miles so far with this setup and had no problems out of it.
