- Thank you received: 8
What should it run in the 1/4 mile
- gvsu141
My question is: what should the bike run in the 1/4 mile approx.
Specs:
z1 900
cams
stock bore size-not sure if compression is stock or not
mr. turbo: i believe it was around 15 lbs of boost
air shift
msd/dyna electronics and shift light
1 piece fiberglass body, custom frame
wheelie bars
also, does anybody have any reccomendations on gearing that i should use?
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
- wildwilly30
1977 kz1000 chopper
1974 honda cb750k chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
1981 yamaha 650 special
1983 kawasaki vulcan
1977 hd sportster chopper
1987 honda vt1100c shadow
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- gvsu141
I know the gear ratios have been changed, he only ran it a couple times since adding the turbo. I know he messad around with the gearing, but im pretty sure the ratio is still way high.
2001 ZRX 1200
1973 z1 900
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- gvsu141
Is that an LT-1 350 sbc in the background?
Yup! Came out of a '95 vette.. has a spun bearing i believe
2001 ZRX 1200
1973 z1 900
- PLUMMEN
- Thank you received: 104
- TerryK
im thinking its only got one carb guys ,but i could be wrong! :laugh: the times are going to depend a lot on whos riding it,im gonna make fearless forcast of mid-low 10s depending on how it hooks up and how straight it runs
Hence me typing "carB"
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- PLUMMEN
