- Thank you received: 4
Wrench Monkees
- ready2ryde1985
- got to love these kzs
www.wrenchmonkees.com/
simple clean cool!!!!!
thats what its all about form and function shaking hands!
84 kz 700 a1
82 kz550 ltd
- ready2ryde1985
84 kz 700 a1
82 kz550 ltd
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- ready2ryde1985
84 kz 700 a1
82 kz550 ltd
- ready2ryde1985
- ready2ryde1985
84 kz 700 a1
82 kz550 ltd
- Thank you received: 2829
- KZQ
- Administrator
- Thank you received: 1409
Sorry, but I can't get into the idea of sitting on a 2x4. Those seats would make riding a test of mind over matter. It's obvious that the builders don't really ride bikes much other than short hops. Ed
I'm with you Ed! Looks like style is way more important than utility.
Wonder which would gripe the most, your keyster or your wrists?
Actually the bars on this Kaw
look decent but the seat seems a bit thin.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- loudhvx
- Thank you received: 1616
That's what I thought until I made my own. With the stock seat, it was way too soft and it would bottom out. I was sore after an hour or so. With the right type of kneeling pad, I can now ride for about 3 to 4 hours at a time, and up to about 8 hours a day. Some of the kneeling pads are indeed too stiff, and some are too soft. The key is to get the right one.
Another trick is to make sure the seat is wide enough. By using a standard pan, the seat is wider when it uses a thinner pad. This actually helps because the seat will support a much larger area. This reduces pressure on small spots which would get sore.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
