- Thank you received: 3
heated grips
- 9am53
- homebrew, and some bbq
cgi.ebay.com/ebaymotors/UNIVERSAL-HEATED...fPartsQ5fAccessories
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Bluemeanie
- Thank you received: 14
- parkingpuckguy
Best way to get the old grips off, and back on, is to spray under them with WD40. They'll slide right off and when put back on do not move around as the WD is evaporated by the heat.
Make sure that you get the heat shrink wrap (or something similar) to put on the clutch side of the handlebar. Without it, you will lose a bunch of the heat to the bar. The throttle side doesn't need it because of the throtte tube.
Good luck.
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
- 1977Greyghost
1977greyghost
The only thing that you can't speed up or slow down....TIME
1980 KZ1000 LTD
2003 Bombardier Traxter MAX
- HerrDeacon
- Bluemeanie
So the old KZ charging systems handle this extra bit of power requirement? I thought about getting them before but figured it wouldn't be able to handle the extra load.
My thoughts exactly! I need some cold weather gloves but don't like the thick bulky feel. Heated grips would solve that problem! One site said they use 36 watts on highest setting.
- Bluemeanie
- 9am53
'84 GPz900r
'71 CB350
- 9am53
I can turn my headlamp off during cold starting and during the day while running the heated grips, but I do occasionally ride at night and would like to use both heaters and headlight.
'84 GPz900r
'71 CB350
