- Thank you received: 13
What was the Worst Bike you've ever owned
- Bad Kaw
- Flying Squirell
Bad Kaw wrote:
I swear...Yamaha...they always have to do something different don't they...I mean they ruined some potentially decent bikes with their addiction to 'shaft drive' (XS11, XJ750, XJ900, Vision) and the 5-valve cyl-head...I mean WTF!!!??? Anyway, those carbs SUCKED, too!
Hmmm, I'm sure others will come...I'll chime back in...
Just purchased a 83 Yamaha 750 SECA. Shaft drive with four carb setup. This Yamahammer is hard to start and keep running ... Inspection revealed the carb to engine boots leaking air due to cracks in the rubber. Bike Bandit wants $220+ dollars for OEM replacements .. after reading some posts concerning Bike Bandit, I'm not so sure I want to deal with them. This bike may take first place in my worst catagory if it is a engineering and maint. nightmare! This bike is a fix, sparkle and sell project so I'm not going to put much cash into it. I'll either make my own boots as I can mold rubber or modify existing OEM Boots to fit.
Advice on the carb-boots: smear clear silicone over them and it will fill in the cracks and seal the boots. Then forget the $220. Good luck on that.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
- Bad Kaw
- Flying Squirell
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
- nads.com
- Thank you received: 20
Ive put crank in a 900 virago, owned a 750. Worked on newer one replaced starter etc. Straight up junk and the starter gear was machined with too much clearance on the shaft so it tilts and kicks away from the flywheel. The 900 ran for years though, long enough to get dumped a couple times even and never broke down. I raise my right hand and state this: I hate viragos. If they start on fire think before u put it out. Without the virago you'll live another day, with it you'll live in the garage. Never trade work on a virago for meth. When they book you they'll be asking about the parts in your pocket, those would be the starter gears. And no, they won't want to talk about them. :ohmy:No such thing as POS bikes, just more involved projects. Virago's are a bitch about starters, but decent power and reliability are good once a 4 brush starter is installed. Never had Vision, but i have heard they are a real pain, Suzuki Re5 the same. The worse bike i had to work on was my '74 Z1, never could get it to run right for me, but learned a lot about carb syncing, rebuilding and cam timing or non timing, 4 broken valves when i timed it wrong), but it was fun. The Virago's (750 and 920) were great bikes, just had to learn a lot about starter rebuilding 101. My current 650 SR started off as someone elses POS project, but with a bit of work and cash infusion it is the sweetest bike i have owned short of my '92 EX500, now that was cremepuff. 55 mpg, 12.7 1/4 mile and handled like nothing else. Should have kept it... One bike that somes to mind as my worst POS was my first bike at age 11, a 1974 Kawasaki KV75. The ignition had capacitor issue and the dealership said it would cost more to fix it than it would cost to replace the whole bike. Bought a 1971 Honda SL70 and rode the piss out of it for the next 4 years. The KV went to the junkyard.
- nads.com
- Bad Kaw
- Flying Squirell
I've still got my other one, and it's always been a pretty decent handler. Seems like that's what you get with a Z1R: one that works just fine and one that wags its head. I have a friend who has two, one stocker and one built; same with his bikes, the stocker shakes its head real bad but the 1260 NOS bike runs straight and true (it better the frame is braced and it's got 17"s and 'beefy' front and rear suspenders).
Oh well...gotta love the Z1Rs, though. :blush:
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
- unomike
- Biker for 40 years.
Also I found a small pinhole in the lower right hand side of the gas tank that needs repair. Plan on brazing the hole closed and re-painting the tank. Since I weld for a living this is a no-brainer for me. This will be the third tank I've brazed up in two years.:woohoo:
Own: 1980 Kaw KZ1300,Stage 1 kit,K&N pods
1972 Harley Davidson XHL Sportster, 1972 Suzuki T500, 1974 Hodaka 125 Dirt Squirt, 1980 Honda 250 VTR, 1983 Yamaha 750 seca and a 1974 yamaha GT80 for my son.
Bristol, Tennessee. USA
- grumpy56
- Thank you received: 6
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- tooocool49723
'82 kz550. Bought it for $300 because someone unplugged all the wires and the guy couldn't figure it out. Fixed all the wiring problems and got 'er running. Then she decided that she wanted to blow up a fuse while the fuse didn't want to blow. Short circuit later and I get stuck on the side of the road twice with a dead battery.
Fix the fuse, ride her a little more, find out the hard way that the prime position on the petcock doesn't leave a reserve. So, pull the petcock apart to find that someone put the spring on the wrong side.
Fix the petcock, riding around and all the sudden shes feeling slow, then wont move at all. Look down and the front brake is smoking. Take the pads out and ride home on the rear brake, that was fun! Come to find out the master cylinder got plugged up.
Then I decided the headers needed new paint. Took them off and have found a crack near one of the flanges, so that gets to be welded.
And the latex spray paint came off around the gas tank when I spilled gas on it...
Still love to ride 'er though! and she is a great bike most of the time, just a little quirky!
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
- Galactica
77KZ1000
76 KZ900
- Bad Kaw
- Flying Squirell
...damn I hate cruisers...
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
- tomsweb1
But when she was running... it was the most fun bike I've ever owned.
1978 CB400A Hondamatic
1983 CB550SC Nighthawk
1978 CB750A Hondamatic
1982 KZ1300
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
