bike balance
10 May 2009 06:18 #289758 by poolboy
bike balance was created by poolboy
Heres an interesting question for you.
I know you've all had at one time or the other ridden your bike with no hands on the handle bars.
As soon as you let go of the handle bars, in order to maintain a straight ahead direction, sometimes you have to lean a little bit to the right or left in order to balance yourself with the bike in order to go straight ahead.
I've had bikes where you had to lean left and other bikes where you would have to lean right.
What causes this weird behavior. :)
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
10 May 2009 07:11 #289788 by PLUMMEN
Replied by PLUMMEN on topic bike balance
worn tires,bearings,steering head..... could be lots of things B)
  • trianglelaguna
10 May 2009 07:20 #289794 by trianglelaguna
Replied by trianglelaguna on topic bike balance
for me its my left one being bigger.......:laugh: ...road camber ....even a flat road is not flat if you put a four foot level accross it....our inner ear balances us and tells us we are on flat groung most of the time...but everything is based on sea level and slopes .....the bikes have no false balancing systems and read true plumb and level and react.....also as plummen said too, components....there is a place in death valley where you park your car with the e-brake up hill...put it in nuetral and release the e-brake and begin to roll up hill...i shit you not.....been there....good food for thought question though...interesting for folks to chime in on....peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
10 May 2009 07:26 #289796 by PLUMMEN
must go to death valley! :laugh:
  • KZQ
  • Administrator
10 May 2009 07:27 - 10 May 2009 07:28 #289797 by KZQ
Replied by KZQ on topic bike balance
KZ's have notoriously inaccurate alignment marks on their swingarms. If you're going by the marks when adjusting your chain you've probably gotten your rear wheel out of alignment with the rest of the bike. My KZ900 always required me to shift my weight to the right when I attempted to ride without any hands, at least till I started using a pair of strings to set the rear axle.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 10 May 2009 07:28 by KZQ.
10 May 2009 07:34 #289799 by 650ed
Replied by 650ed on topic bike balance
Another contributing factor is what I will call human dynamics. Try this, get a good bathroom scale, preferably digital, and stand with one foot on the scale and the other foot on the floor. Try as hard as you can to keep the reading on the scale from going up and down. I cannot keep the scale reading one weight for more than a couple seconds no matter how hard I try, so my weight is shifting left and right no matter what I do (and I haven't had my first drinky-poo today). - Just a theory. Ed
  • Kawickrice
10 May 2009 10:04 #289868 by Kawickrice
Replied by Kawickrice on topic bike balance
There is a place in Florida called Spook Hill that does the same. Put it in neutral and roll up the hill.
Components like PLUMMEN described is what I would suggest
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
11 May 2009 06:39 #290162 by poolboy
Replied by poolboy on topic bike balance
Great ideas. KZCSI, please explain how you use strings, obviously the strings are the same length. Do you measure from the swing arm base to the axle ? :side: This could be tricky, I'll take notes. Thanks
  • trianglelaguna
11 May 2009 07:01 #290165 by trianglelaguna
ill let bill explain how his method works but the one i have seen you make a big loop like a rubber band and run it around the tires front to back about four inches from the ground...if the front wheel is poiting straight the the strings will be touching the rear tire in the same way if they are touching on one side and open on the other you simply turn the adjusters out back untill all tire sides and string sides touch the same...you can google motorcycle string alingment for photos....peace
1976 KZ900
2003 ZX12R
2007 FZ1000
11 May 2009 19:44 #290394 by poolboy
Wow thanks a bunch for that tidbit. I googled motorcycle string alignment and geez I sure know how to align wheels now. Thanks for that....
  • KZQ
  • Administrator
11 May 2009 20:33 #290417 by KZQ
Today, I actually use a lazer to project a straight line from which I can measure the offset at each tire.
But I did start off with the strings. Start off by making a loop that will encompass both tires. Set up the strings so that they run evenly off of the rear tire and measure how they fit with the front tire. If you've got a center stand you should be able to guess at what amounts to straight ahead if every thing's in line you should find that the measurements are symmetrical.
Hope this helps.
Bill R
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • l0g1c
  • Hanging on for dear life.
11 May 2009 20:37 #290418 by l0g1c
Replied by l0g1c on topic bike balance
KZCSI
Oh man, thanks for posting this. I'd never heard that and thought I was going nutso for the past year. :woohoo:
'81 KZ750 LTD
'72 CB350K
Omaha, NE
